Acer Aspire 5050-3242 Notebook Logo
Anonymous Posted on Apr 03, 2010
Insert battery hang not working
My laptop is acer aspire 5051anwxmi,insaer battery hang ,power metre error.if connect ac power,good work every things,how to solve please?
Anonymous
Level 2:
Sergeant:
  • Expert 256 Answers
  • Posted on Apr 03, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
256
Questions
0
Helped
64332
Points
717
Have you tried using an extra battery? or remove and put back in the battery? if it still wont work, try updating your BIOS, check your website if they have one available.
1helpful
Aspire 2225g works only without battery
You need to replace the battery. A lot of laptops will work from AC adapter when the battery is out but when the battery is installed they default to battery and the AC adapter defaults to charging. When the battery is bad you get the results you describe. If for some reason it did the same thing with a new battery then the power circuit would need to be replaced, but this is not typically the case. Almost every time I have fixed someones Laptop with the problem you describe, a new battery was the solution.
Hello , i have acer aspire 3680 laptop , i have face same problem. when i am connecting ac adepter then my laptop will hang and none of the procedure will work.one another problem is when start my laptop...
Hi
Try to remove the battery and power up your laptop, if the problem is still the same try to press F6 or F8 and start into Last known good configuration. and disable the automatic restart. But back up your data and reformat your laptop. it might have viruses on it that triggering the restart.
Good luck
My acer 5920 wont charge or wont work on ac adaptor but the ac adaptor works fine on my friends laptop
Either the AC port on the back of your laptop has a lose connection - if operation without battery is an issue, or if battery charge only is issue - then battery may have to be reseated or it is at end of life. Test by removing battery and running AC alone. if connection port is bad, laptop will power off immediately/unexpectedly. Good luck! btw - batteries for this unit are around $40 on ebay
2helpful
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
1helpful
Reboot system
my acer aspire is hang insert battery time,ac put normal work,my modle is acer aspire 5051anwxmi
4helpful
3answers
Acer 5670 boots ok but keyboard and mouse don't work. External mouse doesn't work either. can you help?
Just remove the battery
a bad battery disconnects your keyboard from windows
all so you buy a new computer
3answers
Acer 1641 laptop keyboard doesnt work
we removed the battery and used only the AC. all works fine.
Aspire 5600 hangs with battery inserted, without battery works fi
one of 2 things, youre battery might be no more good, i u left a dead battery lieing around for awhile they tend to lose there charge so maybe buy a new battery, but i suggest reformating ur computer using the hidden partion in the acer start screen, when u boot ur computer hold ctrl + f10 this should enable the acer e-recovery management to reset the computer back to factory defaults. Note that everything in ur drive c will be deleted so anything u want to keep should be moved to the drive D. if its not ctrl f10 then search acer e recovery and ull find the correct key combination to enable it
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
