Kenwood RXD25 CD player intermitent??
KENWOOD RXD25 Home Ent System CD/Tapex2/TUNER/phono
Fault in CD refuses to play cds but if you load & unload the disc numerous times & as the disc is loading hit the track button it sometimes loads & will play the full CD perfectly Then its back to the LoadUnload till it goes again, Sometimes it even reads the No of tracks & displays the correct number on the display, the Play indicator comes on but ZERO SOUND
  • Ross Mar 17, 2008
    Thanks for that Graeme, Sorry but already tried the draw load theory but No Go it is loading! The Disc is spinning at all times it will even sometimes read the track times EG total disc time, go from Pause to play, but no sound then next time maybe 1 in 20 it will decide to play a whole 1 hr long CD ,But dont distub it or your back to sqaure 1 again. THANKS FOR TRYING to help Graeme If it wasnt for the sentimental value of the unit I would use it as a WHEEL CHOCK!!
    WITH THANKS ROSS
  • Anonymous Mar 30, 2014
    player plays some cds but most of the time cannot read cds
  • 1,512 Answers
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Posted on Mar 16, 2008
  • Graeme Ross
    Graeme Ross Mar 21, 2008
    I had more.... give the laser lens a clean with a cotton wool bud moistened with Windex, then polish it with a dry one to be sure no smear is left. It may also be failing spindlemotor bearings that are causing a mistrack whilst the laser is reading the TOC. This happens because it has to spin fastest at the beginning of the disc. Many CD misread and no TOC problems are caused by lazy spindle motors. Anyhows, you have thanked me for trying, although I have repaired more than 1000 kenwood cds over the years. Cheers for that. I still got more but have lost interest now. No gains for me here
SOURCE:
Kenwood MP3 CD Player not working in a daewoo matiz
If all disks do not load the player is fubar and needs replacement. No getting around that.
Sep 11, 2017 | Kenwood Car Audio & Video
Cd player will not play cd's. Error code: TOC ERR
A few things it could be:
No disc has been loaded in the disc magazine.
CDs being used are burned, test using different media or an actual CD.
Very dirty or scratched CDs.
The CDs are upsidedown.
Sep 21, 2011 | Kenwood KDC-MP4028 CD Player
I want tohook up a Kenwood KA-88 Amp. to a KT-58 Tuner to a DP-M5540 disc player and KA-68W Cassette deck. how do I do it?
Find the manuals or go by the basic INs to OUTs rule. REC = OUT, Play = IN. "Tuner" and "Aux/CD" are not literal. They're for anything BUT a turntable. But remember ONLY a turntable would ever use "PHONO".
This picture shows the rear of the KA-88
http://www.canuckaudiomart.com/view_images.php?cat=Amplifiers&catnick=amplifiers&cfid=168328&image_id=1469879
Register and download the CD manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-DP-M5540-CD-Players-manual/id/479ag101/t/2/
Jun 28, 2011 | Audio Players & Recorders
I have a Kenwood mini hifi system XD-A700 i cannot open the CD player drawer to play cds.I dont have an instruction manual.
You can download the manual at
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/xd951.pdf
Aug 29, 2010 | Kenwood XD-A700 Shelf System
Connection compatibility
Connect the supplied short RCA "Y" adapter cable to the mini jack of the transmitter base unit. Connect the "Y" adapter plugs to the TAPE 2 "REC" L and R jacks. These jacks will supply "line out" levels of any source selected at the Kenwood to the EWOS1 internal amplifier. The line out levels are "fixed" so changing the volume levels of the Kenwood will NOT change the volume out of the EWOS1 speakers. The EWOS1 volume will be controlled by the volume up / down buttons on the front of each speaker, or by the incuded remote when directed at the speaker(s).
The signals from the TAPE 2 jacks are ALWAYS on regardless of the source selected, so the Kenwood volume can be turned to minium and still provide an unchanged sound level from the EWOS1 speakers. Likewise, if listening to FM, Phono, CD, etc. in the room that the Kenwood's speakers are located, the OWS1 speakers will by playing the same FM, Phono, CD, etc program - unless they have been powered off. The point is, that unlike having to choose FM, CD, etc to listen to those soreces, you should never select TAPE 2 as a source. If TAPE 2 is selected, the KENWOOD would attempt to amplify TAPE 2's "PLAY" jacks, which I assume are not being used.
Mar 20, 2009 | Audio Players & Recorders
Kenwood cd stopped pla computer made cds after i dropped it now will play for about 1min then stops
hi 1paullawrenc, try get your lens cleaned by using a lens cleaner hope this solve your problem.
raj..
May 11, 2008 | Kenwood CD-203 5-Disc CD Changer
USB and CD Player Stopped Working
Checa en el manual si no activaste un candado con el usb.
Apr 09, 2008 | Kenwood KDC-X591 CD Player
Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Dec 06, 2007 | Kenwood DP-J2070 CD Player
Kenwood KDC-2011S display blinks
Download the MANUAL here.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=037b5697f7192f25431654464fa26ba6&q=Kenwood+KDC-2011S
Enjoy!
;) Mak
Aug 22, 2007 | Kenwood KDC-2011S CD Player
Kenwood KDC-2025 won't play CDs
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ^^^^ ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. I suggest the lens needs a clean, or someone has dropped it and broken the delicate lens mech. Luck
Apr 30, 2007 | Kenwood KDC-2025 CD Player
174 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
