In turnong off the unit hitting off button the dish is off & tv screen is still blue & will not turn off
    Brigadier General:
  • 6,966 Answers
Hi again,
Thank you for using FixYa's Live Session. After the full hard reset, pls post any updates/developments.
Hope this be of initial help/idea.
Good luck and kind regards.
Posted on Mar 16, 2008
How to get full picture on my tv?
First, ensure your tv is using the highest resolution possible (Usually 1080 for flat screens) by using an HDMI cable from the receiver to the television, and that you are on the correct input. Second, ensure your tv is not sizing the video by using the 'picture size' or 'aspect' or 'ratio' key on the remote that came with your tv (Not your DISH remote). Third, tune your DISH receiver (with your DISH remote) to an HD channel (for VIP model receivers, when you tune the channel to an HD channel, an opaque white 'HD' appears insude the blue box at the top of the screen). Fourth, hit the star key on the remote, while watching the screen. On the right hand side, near the top, it will cycle as you hit repeatedly the star key, the style of screen widening. Hit the key as often as you need to make the screen appear the way you want it to. The receiver will remember your setting for all HD channels. When finished with the HD channel, tune your receiver (with your DISH remote) to a SD channel (any channel in the guide that does not have the HD icon). Repeat the fourth step.
For Hopper/Joey family receivers, hit menu, settings, screen size. Follow the instructions to resize your screen to match your preference. When finished, repeat step four above on each an HD and a SD channel.
Mar 15, 2015 | DISH Network Televison & Video
I turned dish on and all I get is snow
Check the input cable to dish box for firmness and the orientation of the dish.
Feb 16, 2015 | DISH Network Televison & Video
How to hook up Dish Network Receiver
which Dish Receiver do u have. if it is a Dual Tuner (322,625,622, 722) u run a RG6 Coax from the Dish to the back of the Receiver. on back of the receiver there should be two ports (Dish 1,, and Dish2) u will need two short pieces of coax and a Separator ,(which should have come with the Receiver. u hook the coax from the outside Dish to the single port of the Separator , now u run a coax (or RCA or what ever) to the TV. Turn on TV and Receiver.
on the Dish remote u hit the Menu button and hit #6 then #1 and #1 again (wait for each screen to change ) u should see a signal bar at the bottom. U will need to get someone to turn the dish a little at a time till u get a signal. once u get a strong signal u hit the Check Switch and let it program.
Sep 23, 2014 | DISH Network Televison & Video
How can i change the video input on my rca truflat tv 27F520T without the remote
As there is no Menu button on its front panel. you can't select inputs to this TV without a remote control.
Jun 05, 2012 | RCA TruFlat 27F520T 27" TV
Dish network Blue screen No "Signal
Hi john harrison!
A blue screen with "No Signal" is usually related to a video problem. The TV may be getting changed off the correct input/channel, or the video cable might be going bad.
If you have a spare, I would recommend a different cable and seeing if that fixes the problem. If it continues, verify the input/channel your TV is on when it receives a picture and if it goes out try putting it back on that input/channel.
If problems still continue I would be happy to review additional options with you. You can reach me here or at thomas.faust@dish.com
Tommy Faust
DISH Social Media Representative
Jun 03, 2012 | DISH Network Televison & Video
Turn off and on, blue screen
Hi, I am sorry you are having a problem with your DISH video. A blue screen means you are on the correct channel or input on your TV. If you turn the Tv off and then back on, ehat channel ot input does it say it is on. You should be on channel 3 if at TV1 or 60 or 73 if at TV2. If the receiver is connected to the TV using the Red/ White/Yellow cables, then the TV needs to be set to a video input. If you any additional assistance, please email me directly. Thank you!
Mary Catherine Brady
DISH Internet Response Team
marycatherine.brady@dish.com
2:45pm-11:15pm (MST) Tuesday-Saturday
Jun 03, 2012 | DISH Network DVR-625 DTV Receiver /...
Blue light is on and a blank screen on tv remote does nothing tryed hard reset with no change
Hello! Daniel Busa here with Dish Network customer service. The blue light simply means tv2 is up and running, you need to get the green light on. If it's still down hit th sat then power. If that doesnt work, hit the channel up button on the box system info should appear hit record three times, and then select, then power and it should start running again.
Dec 11, 2010 | DISH Network 322 DTV Receiver
I have an Olevia 42"
The issue you are having is your power supply
Thank you
www.orlandolcd.com
Dec 07, 2010 | Olevia LT42HVi 42 in. LCD Television
TV input
it is likely that your tv is interpreting a random button on your remote as a signal sent for it to change inputs, next time this happens turn the tv off and back on and note what comes up on the screen, for example video 1,
Aug 04, 2008 | DISH Network IR Remote Control
Pink and blue images occasionally on power up of DISH DVR
Tell me a little more about how the receiver is connected to the tv and if this is present on both tvs at the same time and lastly what brand and model of tv you have. I recently had an issue somewhat similar to this but need more information to make an educated hypothesis.
Apr 18, 2008 | DISH Network ViP622 DVR DTV Receiver /...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
