Home | Magic | Sing Along Consumer Microphone | Magic Sing EG-18000 Mic...
Magic Sing Along Consumer Microphone
Problem for Magic Sing Along Consumer Microphone
Magic Sing EG-18000 Microphone Delay
By lovemykids on Mar 16, 2008
I just bought the Magic Sing EG-18000 and there is a sever delay on the microphone.  When you sing into the mic, it takes 2 seconds for it to come out of the TV speakers.  I am using the yellow, white and red wires into a Video out port on my TV.  Any ideas, please?
Clarification Request
Posted by alpeve on Jun 14, 2008
i specifically have a SHARP AQUOS 32" HDTV that i've recently purchased. on the back of it are several connection ports, marked Input 1, Input 2 and so on. each Input has a set of video/audio ports and i basically connect my magic mic in those ports, just as i did with my old tube tv. i also have external speakers connected to the audio port. i've tried moving the magic mic connection to the different Input ports but still no luck.
Same Problem
Apr 24, 2009
-   I have the same problem... Severe delay when connecting to my Samsung LCD. I later bought a Samsung surround system, and connected the audio directly to that. Same problems.....-   Guest
Jan 30, 2009
-   I can't even get it to work on my plasma TV- can someone help? I've pluged in the av inputs and nothing. Do I have to put the tv on a specific channel? Or adjust the TV settings somehow?
If anyone can help I'd really appreciate it.
-   qnsmale75
May 12, 2008
-   I have a new 9000 with an extra microphone and I have the same issue. The audio out of the tv is delayed from the singers voice enough to throw off the timing of the singer. I have an older model Magic Sing that hooks up identically to the 9000 and it works perfect. Is the 9000 just a cheap version?-   zp18
May 11, 2008
-   i have the same problem and it's frustrating!!! HELP!!! :)-   alpeve
Mar 19, 2008
-   I have the same problem too, when I select and press the number of song title there is no title song appear on the tv. at the same time there is a delay of music lyrics at the bottom of the tc screen. please help me. thank you.-   edgarsky
Best Solution
posted on May 04, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Your problem is your connection to the TV and maybe your Magic Sing configuration.
Can u specifically describe how you have it connected?
Solution #2
posted on Jun 14, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I fixed mine the same way. I do not know why there should be a delay going through the RCA inputs on the plasma TV, but running the audio through a separate amplifier with only the video going into the RCA inputs works with mine.
GWB
Solution #3
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have an ED8000 which worked fine until we got a plasma tv and a HDD/DVD recorder. Each adds a delay to the audio which creates and overall echo and long delay which is unacceptable. I fixed it by running the video direct to the TV and the audio direct to the amplifier. All echoes and delays now history. You might need an extra extension audio/video cable but it worth the effort for ~ $3.
Solution #4
posted on Sep 17, 2009
Not Rated)
19kath89
Rank: Apprentice
Rating: 100%, 1 votes
i bought et18k. just the same as yours.its 2 days old and has the same problem. the technical assistant says that its because of the digital setting that new tvs have. there are two ways to solve this though:
1. connect the video (yellow plug) to the tv. and the other two plugs (yellow and white) to the stereo. when i say stereo, its not the dvd home theater system that you have but a separate one. if you connect it to the home theater that you have, it'll just sound the same, you still have the delay.
2. connect the magic sing to the older tvs hangin out. and you'll get no problem at all.
**TVs such as sony, samsung, philips, sharp and all plasma tvs including other newly designed tvs will have the delay since they all share the HDMI thingy that causes sh*t.
Was this helpful?
Yes
No
Popular Solutions for Magic Sing Along Consumer
Questions and Unsolved Problems for Magic Sing Along Consumer
Do you recommend Magic Sing Along Consumer Microphone?
Answer
Answer
I have an ED-11000 Entertech Magicsing karaoke set. One of the wireless mics runs out of charge only... (More)
Answer
our magic singalong microphone that we bought in the philippines suddenly stopped working properly.... (More)
Answer
no power on magic sing and wondering if it's fixable? tried battery and different outlet for ac/dc... (More)
Answer
magic sing microphone makes crackling, sizzling noise when I use it, can't hear my voice, just the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Magic Sing Along Consumer...:
Top Microphone Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Microphone Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
