Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Bad start capacitor?
Is there an easy way to check the start capacitor? I smacked the compressor with 2x4 and a hammer a few times and nothing changed. I really appreciate the help.
    Novelist:
    Champion:
  • 236 Answers
Hello !
You can look at the start capacitor for signs of leakage. Also check to see if it is getting hot.
If you can get a replacement that's the best way to confirm it being bad unless you have a capacitor tester.
I think you said the compressor was getting hot. If it is something is stopping it from starting. There is an overload device which is about 3/4 " thick and 1" in diameter which goes bad but if it is bad usually the compressor is dead - - - won't even try to run. The overload is located near the start capacitor.
If the condenser coils are clogged with lint- etc. the compressor will also get hot due to not enough air flowing over the coils. This also will cause you refrigerator to not get cold enough.
I really think you have a stuck compressor. I have been wrong before so it is best to check the cheapest things first. I hope this helps you !
Stargazer
Posted on Mar 19, 2008
What would cause the two exhaust manifold pipes on the passenger side to glow red hot the ones on the driver side does not get red hot 2000 Mitsubishi galant 2 4
Try checking for a restriction in the system. possibly the catalytic converter. are the pipes before the muffler? you can smack your catalytic converter with a dead blow hammer a few times before you start the engine. you will hear a sound similar to breaking glass from inside the converter it's carbon build up. Start the engine and rev it up a little. If it was constricted the carbon you broke loose will blow on out. If nothing is restricted in exhaust you may have a bad exhaust valve on that side.
Apr 04, 2014 | Cars & Trucks
I have undone all the bolts on the water pump on a bmw 318i but it wont come off the motor
try and give it a little love tap with a deadblow hammer OR place a 2x4 on the pump and smack the 2x4 with a regular hammer.
c...
Jan 25, 2011 | 1996 BMW 318
Cant get brake drum to disengage from brake shoes on rear of 2000 kia sportage ,there seems not to be a slack ajusting spur
i have had luck using a flat bar on each side. get it in the drum and pull on one then the other and sometimes both at the same time. also open the brake bleader or crack the line. just keep inching it forward.
Dec 31, 2010 | 2000 Kia Sportage
Thought it was battery but NOT...engine will not turnover. other electrical seem to be working
smack the starter a few times with a hammer. If its a starter issue it may free up.. Or you could jump the terminals on the starter. If it does nothing and you know you have 12v at the starter,, then the starter is frozen. Smacking it a few times will only confirm its the problem if the truck starts. Jumping the terminals will confirm you have voltage because it will spark as you do it if you use a screwdriver.
Also you have a ASD relay in the underhood fuse block. Rotate it with a another like the horn or ABS.
If it starts you found the problem
Feb 11, 2010 | 1999 Jeep Grand Cherokee
Compressor wont start, checked the capacitor, its good,changed the relay,compressor still wont start,it is a kenmore refrigirator
If the compressor is getting power and refuses to start it is likely stuck and smacking it with a rubber hammer may temporarily free it. It will ultimately need replaced. if there is no power the reason will have to be determined, start with the defrost timer...
Eric
Dec 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG LHD30 the compressor does not cycle on
Compressor won’t Start
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Aug 07, 2009 | LG DH30 GoldStar Dehumidifier
How do i take off the front rotor to a 95 grand cherokee 4x4 4.0 liter
Remove the caliper, then give rotor a good solid smack with a large rubber hammer or a 2x4 placed across it for protection and a decent weight hammer. (use wd 40 around center and also through openings where wheel lugs come through.) I know...sounds really "high tech" but it works every time!
Jul 28, 2009 | 1995 Jeep Grand Cherokee
I can hear my a/c unit turning on but instead of coming on it vibrates for about a minute or so and then turns off again.
the compressor is stuck // locked up. the start capacitor may be bad, they have what is called a hard start kit for this problem.Or the unit may be old and leakage past the piston seals has bound the compressor. Or it could have stoped at ust that bad position where it can't get enough ooomph frmthe capacitorr to get it to rotate at this position. If you know somebody with a hammer drill, place a small 2x4 along the base of the compressor and vibrate it with the hamer dreill - this may free it up while you hear it hum. If not, you will probably need a hard start kit
Jun 22, 2009 | Heating & Cooling
Will not turn over
This Sounds Exactly Like A Bad Starter, SMACK the Starter With A HAMMER 3-5 times If it Starts Replace it if It Does Not its Still Likely to Be Starter.
Jun 03, 2009 | 2004 Oldsmobile Alero
240 crank problem
Starter motor or solenoid is going bad or cables are corroded. Clean all cables if car does not crank have someone try to crank it while you "smack" the started motor housing with a hammer or a long solid rod (hitting the rod with the hammer as it rests on starter motor case). Hit it sharply a few times. If it starts, then the starter motor is bad.
Nov 30, 2017 | 1992 Nissan 240SX Fastback
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
666 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
