Question about Casio Exilim EXZ75 Digital Camera
Setting date, time, etc.
My battery went dead, and I can't reset the date and time. The manuel
I have isn't very self explanatory.
sewing@suddenlink.net
  • 3 Answers
Just go to menu dude!....
go to adjust time and date...
its prett much easy from there.
Posted on May 28, 2008
Resetting cmos
The best way to RESET the BIOS back to the factory defaults if you do not know the Reset jumper or there isn't one is to remove the CMOS/BIOS battery and wait for approx. 20 mins for the charge in the BIOS to discharge.
If you cannot wait that long then short out the battery terminals on the motherboard with a paper clip.
Replace the BIOS battery, go into the BIOS setting and set the date and time etc.
May 23, 2012 | Computers & Internet
Need to locate the jumper for the cmos battery on an acer aspire one d257-1417
If you cannot locate the jumper or there isn't a jumper to reset the BIOS (CMOS) back to the defaults then remove the BIOS battery for 20 mins. The battery charge on the BIOS will disappear and when you insert the BIOS battery back into the laptop the BIOS settings will be back to the factory defaults.
You need to go into the BIOS setting to set the Date and Time etc.
Mar 01, 2012 | Acer Aspire One Netbook
How do you reset time date etc on model fm112 after replacing the batteries
Click on the menu of the phone,stroll down to setting click on it then stroll down to phone setting and then click on it then stroll down to date and time setting click on it to set the date and time of the phone and other setting.
Good luck.
Dec 06, 2010 | Cell Phones
My pc automatically get start on plug on .and then it suggest me to press F1 to Continue. when I do this it takes incorrect date and time how to restrict it.I want to start it with start button on cabinet
There can be many reasons...
  • Your BIOS setting is not correct.
  • CMOS battery is down(Most probably).
  • both
You can open the BIOS setting page by pressing keys like DEL, F10, etc. depending on your system's manufacturer at computer startup(post screen). There are lots of wakeup options check them properly.
One of the option is "Restore last state of power Button on failure" which can turn on your computer without touching the power button. you should check these options.
And it suggest you to press F1 because your system's date/time is not configured properly. You can also set Time/date in BIOS also.
If your BIOS Battery(CMOS) is not weak or dead then after setting these values your computer should start properly.
And if your BIOS battery is dead then all the settings will be lost(date/time etc) after a restart and you will face same problem again...
Try changing the Power-button option and Date/Time in BIOS and see if problem persist....if yes then you have to change COMS battery that is on your Motherboard.
Sep 22, 2010 | Computers & Internet
Clearing cmos
The BIOS battery maybe under one of the panels on the bottom of the laptop or under the keyboard.
To reset the BIOS ack to the default settings, go into the BIOS configuration and look at the various configurations, usually there is a setting to load the Default settings, then save and exit, and this would not change the Date & Time setting.
The other way to set the BIOS default setting is to remove the BIOS battery (it is probably a lithium 3volt button battery), wait 1/2 hour and replace the battery, the go into the BIOS configuration and set the Date & Time setting etc.
Jul 04, 2009 | Compaq Computers & Internet
I have a barolo atomic clock, batteries went dead.when I changed batteries I could not get the clock off of pacific coast time. bob pittsburgh
Make sure the day is displayed instead of seconds, then homd down the + button for 5 seconds. Every 5 seconds should advance it on zone. Had same problem and just got done resetting mine this way.
May 16, 2009 | Oregon Scientific FM Weather Projection...
TIME DATE LOCK 0271
This IBM 0271 error code means the Date and Time setting in the BIOS is incorrect and needs to be reset in the BIOS configuration.
This is caused by a dead or nearly flat BIOS battery.
You need to replace the BIOS battery and reset the Date and Time.
Apr 08, 2009 | IBM Computers & Internet
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Manuel and or guide for (1604007) Corded Phone
Chastity, Did you ever find the manuel? I have the same problem as you. bbwatson
Jul 24, 2007 | Innovage 1604007 Corded Phone
Casio Exilim EXZ75 Digital Camera Logo
127 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
