Question about Epson Stylus Photo RX620 All-In-One InkJet Printer
Error message I am scanning photos and get the error message "JPEG can't write to file" I have scanned photos before and never got this message. I tried going to the properties screen and changing to bitmap but still get the same message. What do you think could be causing this problem?
    Genius:
  • 1,447 Answers
Hi-
Its the operating system on the computer since it won't accept this types of images in your computer. Try saving the scanned document on a different folder/ or in your desktop. If everything fails, reformat your computer.
Hope this helps
Posted on Oct 31, 2008
I have the HP C3180 printer and I want to scan in PDF format, not Jpeg. How can I make it change over to PDF
To scan a photo into pdf file, it entirely depends upon the printer software if it has an option to scan into pdf then its fine if it hasn't, then you first need to scan the photo into jpeg and google to search for a jpeg to pdf software and convert it into a pdf file.
Hope this helps you.
Apr 28, 2011 | HP Photosmart C3180 All-In-One InkJet...
How do I scan photos
Although different scanner has different option still I am giving you the general method of scanning.
Put the photo on the scanner (photo face down touching the glass of the scanner) - look the cover is perfectly placed and no light is entering inside of the scanner. Now run the scanner software - select scan item as "Photo" (other options are text or documents etc), select the option "Color" (other option is Black and white or gray ). Select the resolution more than 200 dpi (more dpi will give better output), give path where the file will be saved after scanning or keep it default, choose the file type JPEG is better (other options may be BMP, TIF etc). First you get preview - look the expected scan output - if required you adjust or lace the photo on the scanner better way - then again get preview - if you are satisfied you may select the portion out of the whole preview page for scanning - now click scan. It will give JPEG file in the specified location.
Jun 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Fujitsu s510 scanning photos to jpeg
Please open the "paint" from"start/all pograms/accessories/paint".
one when you open the paint, click on file and select the option scanner and camera wizard.
when it open click on scan and when scan get complete click on file and "save as " and select the formate "jpeg" and save it.
Nov 03, 2009 | Fujitsu ScanSnap S510
Nikon Capture NX will not open black and white jpegs
Nikon Capture when initially installed you have to tell it what types of files to open.... IT has 3 tick boxes for NEF (Nikon Raw Files), TIFF, & JPEg, you actually have to tell it which types you want NX to open. The easiest way to fix the problem maybe to reinstall the program and reset the file association as you install it. Hope this may  help.
Jul 26, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Well I don't know how to scan a photo and file it or take it to print
s.gif Follow these tips to ensure your scanned photo turns out to be a stunning print.
Resolution:
  • You'll want a higher dpi when scanning an image that you want to print.
  • If you want to scan an image and reprint it at the same size, 300 dpi works best.
File format:
  • TIFFs are ideal for printing enlargements, but a JPEG will suffice if you are printing a 4" x 6" photo.
Quick tip:
If you are printing a 4" x 6" image as a JPEG, but think that you may someday want to make a bigger print, archive a larger TIFF file of your photo. Unlike JPEGs, TIFFs can be edited and resaved without compromising the image quality.
Jun 05, 2009 | HP OfficeJet 7310 All-In-One InkJet...
No connection to printer when trying to print jpeg files
This is not a photo printer and JPEG are Photo format files.
Feb 02, 2009 | Lexmark X1270 All-In-One InkJet Printer
Scanner won't scan
Hello, It may be possible that the error msg that you are receiving may be referring to another error. 1st thing I would try is checking the resolution, in some cases if the resolution is too high it may result with numerous issue's if your random access memory (RAM) is not sufficient enough to accommodate the resolution that you attempting to scan with. Try reducing the resolution, also try a different file type, either jpeg or tiff etc..,if all failes check to see if you have the latest driver(s) update for your scanner.
Aug 20, 2007 | Canon CanoScan LiDE 70 Flatbed Scanner
Epson Stylus Photo RX620 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
