Question about Philips 27PT6441 27" TV
Philips TV Fix
I see that you are quite talented when it comes to fixing televisions. Would you mind letting me know what the steps are to fix this TV? It's the same problem that I see a lot of people having, the top few inches of the TV have "rolled over". Thanks much in advance.
Try replaceing capacitor 2465. 10 MFD @ 100 volt. Located on the rear of chassis about midway from left to right
Posted on Mar 29, 2008
Hi! i have a philips 20pf4121/05 flat tv.it won't turn on and green light is flashing few times and that s it.do you know how i can fix the problem?
Not likely to be a do it yourself repair. From the model number it is a 20 inch and if the power supply board is bad may not be economical to fix not to mention quite often on the smaller sets parts do not exist.
Aug 29, 2012 | Philips 20PF4121 20 in. EDTV-Ready LCD...
My tv has black lines going thru it and i want to know if i can fix it
Hi city, my name is John. Welcome to FixYa. Yes you can fix it. Here at FixYa we will walk you thru the steps, kinda like taking your first baby step. All can be done here at FixYa. Thanks for choosing FixYa.....John
Dec 06, 2010 | Philips Televison & Video
My philips projection tv 's colors blend together like a fog or haze... how can I fix this?
Well...sounds like the coolant is bad. Go here, for a step by step instructions if you really feel like fixing it yourself
*please rate*
Jul 31, 2010 | Philips 50P8341 50" Rear Projection...
Philips 60" R/P TV
Hi Charles,
the problem will be regulator in power supply,try changing ic located right in front of chasis when you open back of tv,it has 4 legs on each side it's located on the fly back side,thanks,and let me know.
May 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Flickering blue screen problem
glad it was helpful! I had researched quite a bit before I started and realized there was a real lack of detailed info for the wdx2x25 models so I figured I would take some photos and post while I was at it.
If fixing the PWR board doesn't do the trick, getting the other two out is not as bad as you might think - just tedius. The V26 Chassis Replacment manual (different than the main service manual) has reasonablely detailed step by step instructions to disassemble. Let me know if you need it and I can email.
Mar 19, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Philips magnavox 25tr19 c121 problem
Still need info..? Can you replace soldered in parts.? Let me know.........................T.
Nov 16, 2007 | RCA F31672ET TV
No Sound & No Picture
I had the same issue. The screen would shrink and then expand over and over. After thrity minutes it would correct itself.
After a few months of doing this it just broke - no sound and no videe but the power light was still on.
I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
Sep 21, 2007 | Philips 9P6031C 60" Rear Projection...
Philips 32PT6441/37 32"
I don't know about this particular philips chassis but I've got a phillips tp3281 with a #32d700-7570 chassis with the same problem: apparently common with philips sets. I opened mine up and discovered the burnt capacitor that others have reported, replaced this as recommended with a higher rated one. In many cases this is apparently ALL that is required to fix the prblm (a 50 cent part)unless other components are also damaged which appears to be the case with mine. This repair is about $150 here locally at a shop which I didn't want to put into a relatively old set. Have you opened up your set yet? Do a Google search on your set and you might find that others have had the same problem and a simple fix could be possible. Also you could check the following site as they seem to be quite savvy and responsive with TV repair questions: http://www.tv-forums.com; Hope that helps!
Aug 28, 2007 | Philips 32PT6441/37 32" TV
Philips 32PF7320A black screen
If the power lamp is flashing 5 times when it does this, you may need a new power supply. Otherwise, I would suspect a bad (solder) connection in the power supply.
Jan 14, 2007 | Philips 32PF7320A 32 in. LCD Television
Philips 27PT6441 27" TV Logo
47 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
