Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
I have a 52" Toshiba
I have a 52"; Toshiba DLP TV. The bulb will go on for about a second then it goes off. I know that the bulb is good. What else could the problem be?
  • inept3 Apr 12, 2008
    my Toshiba 52" Rear Projection TV 52HM84 keeps turning off by itself, I then will unplug / replug and turn the TV back on. This use to happen only occasionally, but now this sometimes happens 4 times in an hour. Any suggestions?
  • griffweaver Feb 26, 2009
    I have a 52 HM84 and when I turn the power on, it stays on for a few seconds and shuts off.. then keeps doing it continously. Also I hear a humming soud.
    Sergeant:
  • 233 Answers
The ballast isnt keeping the bulb lit.
Posted on Apr 02, 2008
  • Josh Crager
    Josh Crager Dec 05, 2008
    Inetp3 - if you have any soldering experience, remove the ballast for the light and re solder all connections, I have seen a few like this..
I have a Toshiba 50HM66 DLP TV. I turn it on and after a minute or two the screen goes black but the volume is still present most of the time. The picture may come back a few minutes later but go again.The...
I hope our expert would have provided you helpful info in chat session, if you still need further help, let me know the steps taken so far to solve the problem of your tv.
Thanks.
Sep 18, 2010 | Toshiba 50HM66 52" Television
My Toshiba 52" goes dark. what can I do to fix it.Tried to ajust the brightness but still stays dark.
U replaced the bulb yet on this tv?U used this tv alot at lest two years or more?The bulb life span it over,bulb have limitted life span.
Apr 20, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
Toshiba DLP 60" TV not showing TV programs, sound ok
Have the tuner signal board replaced. HDMI does not use the regular tuner bands, it is bypassed when using hd inputs.
Aug 25, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
Toshiba 52" HM95 DLP green and red LED Blink>
If Fan behind Lamp is not running lamp will not come on,also CK blaster board.
Aug 09, 2009 | Toshiba 52HM95 52" HDTV Projection...
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 52HM84 DLP TV with new bulb but the lights keep blinking
They exact way the lights blink are telling you what the failure is. If the tv is firing the lamp and the lamp is bad, you will hear a buzz sound for about 1 second. The tv tries 8 times before it gives up and spits out the lamp error. Check the user manual for led diagnostics. If you put in a new lamp but still have issues, you've likely got a bad ballast (most common on this model) or colorwheel (less common). Both are part of the optical block (light engine) and I don't believe they're available as individual components from toshiba.
Nov 28, 2008 | Toshiba 52HM95 52" HDTV Projection...
Toshiba DLP Model 50HM66
You, more than likely, need a new lamp
Jun 08, 2008 | Toshiba 50HM66 52" Television
Toshiba DLP 50HM66
The bulbs for this TV seem to go about every couple years. The price has dropped down a bit. I have found it for 118.00.
Feb 17, 2008 | Toshiba 50HM66 52" Television
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
185 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
