Question about Sylvania 6260VF VCR
Tracking We figured out how to adjust the tracking manually but it still has a streak at the top of the screen. It sometimes loses the sound and goes to black and white for only a few seconds. What do you think this may be?
    Scholar:
  • 49 Answers
A CONSTANT streak anywhere on the screen could be a scratch in the tape itself. Losing sound, and ocassionally everything going to black and white, sounds like a dirty control track head.(The audio and control track are in the SAME head (a 3/4" metal cube that the videotape travels on). The control track section is on the upper part, and the audio on on the lower part.
If the control track head's dirty I'm sure the rotary head's dirty too! Losing audio and have tracking problems, point to dirt. And you MAY have SO much dirt built up on that head it's scatching your tapes (unrepairable), and causing you problems. Make sense?
Posted on Mar 16, 2008
When playing back vcr tapes on my magnavox ZV427MG9 A, i have a tracking problem with tapes recorded on slp. i get white streaks on the playback, and manual tracking does not help. tapes recorded on s
The VCR has at least four "heads" two are for 2 hr and two for 6 hour (sp and slp)
It is most likely one of the heads used in the SLP mode is slightly blocked with tape debris--heads need to be manually cleaned in the right way.
Jun 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Where is the tracking on this VCR toshiba w403?
On this unit there is no manual tracking button - it's done automatically by a special circuit that uses the special signal from the tracks themselves. If the tracking is bad then the heads are dirty and they don't pick that special signal.
Clean them with a special cleaning tape. If you can't source one the unit will have to be dismantled and the 4 heads will have to be manually cleaned with a q-tip moist with alcohol.
Jul 26, 2011 | Toshiba W403 VHS VCR
I can't figure out how to adjust the tracking on the vcr.
sometimes the channel up and down buttons are also the tracking buttons
Jan 03, 2010 | Philips Magnavox DVD/VCR Dual Player
I have a Craftsman 10 inch band saw. The blade keeps coming off. I can't find my manual. How do I adjust the alignment on it?
the blade tension shaft in the rear top of the saw should also have a tracking adjustment knob that tilts the top wheel. Open the top guard and spin the top wheel by hand and adjust the tracking knob until the blade atays on. Better unplug the saw until you get this done, then you can power the saw back up and fine tune the tracking while running until it is perfect. hope this helps you.
Oct 17, 2009 | Saws
Streaks in playback
the first thing i would do would be to try a head cleaning tape-if that doesn't help see in your book or menus if you can adjust the tracking on the camcorder-when the tape heads get worn over time they need to be aligned and that is what tracking does-some older models allow you to manually adjust-good luck!
Jun 12, 2008 | Canon ZR60 Mini DV Digital Camcorder
Tracking seems off
I have had the same problem. There is no way to manually adjust the tracking on this Hitachi, or on most 8mm cameras, for that matter. I copied all of my more recent tapes to DVD first (2 copies of each) and then I went to the oldest tapes, which for some reason were OK. When I got to one tape that gave me trouble, I just let it play in the camcorder for about an hour. It adjusted its own tracking so that the picture was OK. Then, I rewound the tape and copied that one. I still have 2 tapes that will not adjust. I am going to send those out to a copying service. I hope they can adjust the tracking and make the copies I need.
By the way, I used this camera and a Panasonic DMR-E55 to make the DVD copies.
Jun 04, 2008 | Hitachi VME545 Camcorder
Picture blinking on a Sharp Quos HD TV
Is the VCR sitting on top of your TV? This has caused problems in the past...accordianman
Feb 18, 2008 | Panasonic PV-8400 VHS VCR
Samsung DVD/VCR
It means that it is adjusting the sound from mono to hi'fi... probably because the tape is dirty/damaged or (more likely) the unit needs to be seriously cleaned. Try a cleaning tape, and if that doesnt work have a shop clean it.
Sep 20, 2007 | Kenwood DV-5050M Multi-disc DVD Player
No picture
This type of problem may be caused by a dirty video head, people some time try to adjust tracking to take care of this problem this is a mistake. Now to clear up this issue first you put the tracking control mid way in its setting, then you clean the heads of the VCR you can use a head cleaning tape (follow the instructions on the cleaning tape box)for this or if you have experience you use a chamois swab type cleaner (follow the instructions on the package of swabs and liquid cleaner). one the heads are cleaned you acn then try to adjust track to obtain the best picture. If you can not you may have video head problems or a problem in the drum motor (servo) mechanism. In which case I advise taking the unit to a TV repair shop.
Sep 13, 2007 | RCA VR552 VHS VCR
Televison & Video Logo
220 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
