Van sporadically dies after 10 min drive when pulling into parking lot.. The van starts back up again right away and runs smooth and has good power. Changed fuel filter - fixed for awhile. First time insides of fuel filter fuel looked nasty , next time ( 6 months later ), fuel didn't look bad - changed filter anyway problem went away for awhile ( about 6 months ), It's back again, need help, most be more then just fuel filter. Thank you for your advice.
Try removing the idle speed motor on side of throttle body, and spray it clean, as well as the port it came out of, with throttle body spray cleaner. Don't pull and extend shaft of idle motor, just leave it in position it's in, and make sure you don't lose small "O" ring on idle motor. Re-install and try it. If it cures it for a while, then starts to do it again, replace the idle speed motor.
Please advise what engine, and if you are familiar with AIS motor on throttle body. Does it basically stall quite often when AC, or heater is on, and brakes applied, or turning and off the gas?
