Question about Sony Playstation 3 (PS3) Console
My ps3 does not put out through av/hdmi/or sound
Ps3 does not put out any video single. Have trouble shot with Sony however I can't find my reciept and they said that If I don't have it they won't service my ps3 and it will cost $150 to fix it. Does anyone have any ideas to what it may be.... I have tried the reset to default by holding the power button in, and waiting for the two beeps .... i have held it 5, 10, and even 20 seconds .... no difference just no output at all.....
  • wushufuzz Mar 17, 2008
    just bought 2 weeks ago made back feed noise through the tv speaker and a line flikered up and down the screen every once in a while. When I swiched my input on my TV while ps still on every once in a while a horible buzzing would drown out the TV noise. Then chaged back to input with ps and could here the controls working but no video signal would come through.
  • Anonymous Mar 17, 2008
    I used hd cables at a friends house went back home and now have the same problem
  • 4 Answers
So....what your saying is the video on your TV wont correspond with your ps3??
Posted on Mar 16, 2008
SOURCE:
I have a new slimline DVD and a sony bravia HD tv. My PS3 worked with the basis cable and I recently purchased an HDMI cable and now it won't work on any of my 6 AV channels, including 1 of the 2 HDMI...
All you have to do is reset the video settings on the PS3. Hold down the power button until you hear a single beep, then press it again.
That should have reset the video settings so you can play on the new TV.
Regards.
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
I had my ps3 hooked up to an hd tv but my tv broke and i have it hooked up to an old tv now. I'm having trouble getting a picture or sound is there any way I can configure it to my old tv?
you need a tv with hdmi to connect too then change settings back to normal but you need it connected to both hdmi and component av at once so you can switch between them both to save the settings. so when you change from hdmi to av you need to change your tv channel from hdmi to either video 1 or 2 then save your settings... hope this helps!
Jan 10, 2011 | Sony Playstation 3 (PS3) Console
Cant get picture on psa3 slim hdmi or av
conect your ps3 with hdmi to TV then put your TV on hdmi by its remote controler, ps3 is still turned of. Then press switch of/on ps3 buton and hold it for 5 - 7 second cca., You will hear a double beep sound and after that you can turn your ps3 on. Then just follove the instructions.
Dec 23, 2010 | Sony Playstation 3 (PS3) Console
When i plug my hdmi cable into the back of my PS3, it says no input on my TV ?
you need to connect both the yellow red white cable and the hdmi cable into your ps3 and go the yellow red white av channel
go to the ps3 settings and change the video settings (ithink) to hdmi and also change the sound to hdmi
the screen will go blank and then the tv should change to the hdmi av channel if not change to it and accept the changes
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
No signal on my TV
try connecting the ps3 to the HDMI only, now when the ps3 is off and all but the single red light is on rest your finger on the on button for about 8 seconds, as soon as you touch it it will turn on but just wait a bit and you'll here the a second beep- this should reset your ps3's video output settings. Try it out, it works for me when i go back and forth from av to HDMI.
Please remember to rate my response if helpful.
May 30, 2009 | Sony Playstation 3 (PS3) Console
Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Oct 05, 2008 | Sony DAV-HDX500 System
PS3 No picture or sound
When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
Audio but no video
when the ps3 is in standby, press and hold the power button for over 4 seconds, it runs the optimal screen settings for the ps3. hope this helps
Mar 30, 2008 | Sony Playstation 3 (PS3) Console
Ps3- hdmi to av
unless there is a switch on the ps3 itself to change to normal tv, you may have to reconnect the ps3 via HDMI and change the screen resolution back to 480p or change the settings in the setup from hdmi to av.
Aug 24, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
99 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
