I turn the unit on I have power to the unit. I put a tape in to play and the tape does not play. nothing happens. the last time I used it was about one year ago.is there some kind of belt drive motor or something not working?? It is a pioneer stero double cassette tape deck madle CT-05W it is about 34 years old.
    Scholar:
  • 178 Answers
The belt drive unit is only ran by a SMALL rubber band. It may be that the actual band is broken or the motor itself is shot. Unplug the stereo from the wall and remove the cover CAREFULLY, look in at the tape drive and check the "RUBBER BAND" first.
Posted on Mar 16, 2008
I took my Pioneer SX-450 Receiver and Pioneer CT-1040W Tape Deck apart to move it. Put it back together. Now can't get a tape to play.
After putting a known good tape in the deck, push play, if the tape doesn't move, try rewind and FF. If nothing happens, the deck has a problem. I assume this is a cassette deck. If so, I always try the thrift stores for a new(used) one. There are good bargains there.
Dec 22, 2016 | Pioneer Audio Players & Recorders
After a long period of non-use,of my VCR, I recently tried to play a new VHS tape. It loaded properly, but refused to play it.
Could be the belts have become too old for the unit to function. you could try to take the unit apart to clean them.
Mar 25, 2015 | JVC Hr-a591u 4 Head S-vhs Hi-fi Stereo Vcr...
Cannot play a VHS tape. Push in and pops out.
The belt on the loader motor is slipping. This causes the tape to not completely position itself to allow the tape to load around the drum. The machine senses this and ejects the tape.
Feb 20, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
VHS Stuck; Cover is off; nothing moves...wheels, tape...nothing...help
Unplug the unit, then plug it back in WHILE holding down the EJECT button ... The tape should come out unless there is a belt broken, missing, or loose.
I have used old, inoperable VCR's for tuners only as well. What happens if you leave the tape in all the time? Does the tuner work like that?
May 16, 2017 | Televison & Video
My Emerson stereo MS9903TTC won't turn on. It was working fine last night and this morning when I push the power button nothing happens. I tried selecting different modes, (cd, tape, phono, tuner) but no...
I had the same problem the power button is pushed in. You did not mention if your unit came with a remote control if it did use that to turn your stero on and off. you will not be albe to use any of the buttons on the stereo if the controls are listed on the remote IE; Cd player, radio tape or tuner. try this please. hope this helps
Feb 10, 2010 | Emerson Audio Players & Recorders
A problem has occurred the last time the ps3 system was last used, and the system did not turn off correctly. after that thing pops up after i turn it on i press yes send to ps3 place and then it sends in...
Try a video reset first.
While the PS3 is off (red led)
Hold down the power button until you hear the second beep, quickly release.
Let me know if that solves your problem otherwise it's a corrupt file system.
Nov 20, 2009 | Sony Playstation 3 (PS3) Console
Not recording or playing back recorded tapes
first leave your camcorder with the cassete draw open in a warm room for 24 hrs.
then, use a brand new cassette & re try.
if you get the condensation message, it means the unit has detected moisture on the heads, the unit will not operate... hence your problems.
May 09, 2017 | Sony Handycam DCR-HC14E Mini DV Digital...
PSP no power
Try taking the battery out and plugging it into the wall with only the charger and see if it turns on. does The green light came on?.
Jan 01, 2008 | Sony PlayStation Portable (PSP) Console
VCR
you have probably bent the tab that holds the tape end sensor or its light. The tapes have a clear section at the end of the tape and the light shines through to the sensor to tell the unit that the tape is finished. The light should not pass through the recordable part of the tapes. If anything is bent the light may shine on the sensor and tell the unit you're at the end of the tape and to shut off. Some units have a tape tension sensor also that tells the unit that the tape is broken and to shut off. Only way to know is to remove power and take it apart and look for anything that may be bent. Stay away from the rotating head assembly and the posts that the tap travels on. Do not apply power with the unit open. Do not load a tape and remove power as some units freeze in the loaded position and will not load new tapes unless manually placed back in the unloaded position.
Oct 17, 2007 | Emerson EWR20V4 DVD Recorder/VCR
VHS player stops after 5 seconds
Hi, Based on your post/description, sounds like a mechanical problem with the take-up spool. As this would involve mechanical diagnosis and repairs, your best bet may be to seek the services of a qualified professional. Should you want to venture do-it-yourself, you need to remove the top cover and expose the inner mechanism of the VHS tape player. Of course the usual safety precautions when working with electrically powered devices. Once the inside mechanism is exposed, you will notice that there are 2 spools where the tape would be sitting when fully loaded. The right side is the take-up spool responsible for winding the tape when played or fast-forwarded. When fast forwarding during stop-mode it is direct gear driven however during play and fast-play, the take-up spool is driven by a clutch sandwiched between the top portion and the bottom wider portion. You need to disassemble the take-up spool. It may be held in place by hard press, force-fit, lock or retaining clip. Normally there is a spring near the top. Upon disassembly, you will notice the clutch which is a white fabric/cloth/cotton appearance. This has to be replaced. Probably available in eBay. In my location, such spare part is not readily available and we have to make do with work-around (not necessarily technically right but as long as it works and for your info only). Things we try:, Stretch the spring, the idea is to put more pressure on the clutch when assembled back; roughen the contact portion where the clutch mates with the spool assembly; worst case scenario, forget the clutch, dab a drop of rubber adhesive on both sides of the clutch. In certain models/versions, it is possible that a slipping belt is causing the problem. In some instances, it could be the driving motor. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 18, 2007 | Funai PY90VG DVD Player/VCR
111 people viewed this question
 Grubhead
Grubhead
