I can not seem to open the compact disc.I did what the manual said and follow all the instructions.I can not seem to open the compact disc.I did what the manual said and follow all the instructions.
You can't post conmments that contain an email address.
You can't, it is an antique. You can get a reasonable Bluetooth speaker for $20, or if you want to something to fill the house with concert quality sound, a Bowers and Wilkins Bluetooth speaker. I have four of their products.
First check that the speaker wires are not shorting, if okay! the problem is in the audio output stage of the receiver, the protect mode comes on if a load is detected.
Have it first cleaned by a cd disc cleaner or if you are familiar with cleaning the lens manually im sure that will work...or try inserting an original cd's,if it works with that find the solution to the settings of your device...
A desperate longshot but the only i have to offer:
It might be a problem with the electricity.
if possible try and install it at another location in your house, using other electricity sockets.
If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity.
Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances.
If the problem persists, and you are still under warranty, I suggest contacting your local JVC dealer. If you're out of warranty I suggest locating a professional repair person.
Good luck
