Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Kenmore compressor cycles and does not cool
I have a kenmore side by side model # 106.52532101. The fan runs and the compressor kicks on for 7 seconds and kicks right back off and is warm. Both sides of the fridge are warm, one day just stopped working. Could it be the relay? Thank you for your time.
    Novelist:
    Champion:
  • 236 Answers
It sounds like you have a stuck compressor or bad start capacitor.
Stargazer
Posted on Mar 16, 2008
Need info for a kenmore side by side refrigerator model#59652673202 it it not cooling nor freeszing ; the light works and the fan works but not cooling any side please help me
Good day,
With that amount of info it would be hard to try to pinpoint it. Here's a list of items that can cause a refrigerator to not cool.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condenser
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
As you can see it could be one of many,many items. If your handy with a meter you might want to start at the bottom back of the machine where the compressor is located.
Sounds as if it is not running, or running without refrigerant in the system.
Also, if it has a cooling fan motor in that area, make sure it runs, since all fan motors are wired to run at the same time.
Oct 15, 2010 | Kenmore 44103 Side by Side Refrigerator
I have a 10+ year old Kenmore side by side that quit cooling
the starter unit of the compressor can be bad EZ fix if it is that...its the element conected to the compressor :)
Dec 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Coldspot compressor kicking on and off
It sounds like you may have toasted one of the starting componets. Either the start relay or the start capacitor has probably failed, causing the compressor to try to start, and then kick off on overload. Hope this helps
Sep 10, 2009 | Kenmore 50522 / 50524 Side by Side...
Model 106.53632300 couple of days ago smelled something (burned electrical type smell). Now both fridge and freezer not cooling. Cooling fan in back on bottom is running.
you may have a fried start or run cap and hopefully not a spendy board like everything runs on these days....bad caps(capacitors) will cause compressor not to start and run but arent needed for fans to kick on ....
Jun 28, 2009 | Kenmore 53642 / 53644 Side by Side...
Fridge is not cooling freezer is not freezing
Your compressor is seized and is cycling on intenal overload, you will have to get someone out to get a price at replacing the compressor for your fridge.
Apr 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Fridge and freezer not cooling
Compressor is probably out on thermal cutoff from trying to restart continuously. You can get what they call a hard start kit at a parts house. Its a plug and go unit.
Jan 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Side by side not cold
compressor overheated or stuck. also check starter relay...maybe broke.
if ever thing is alright,
let it stand for about 4 hours unplugged to cool the compressor.
plug it after 4 hours and if the compressor would still run for 10 seconds, then you have a faulty compressor.
tnx 4 using fixya,
drcool
Sep 09, 2008 | Kenmore Refrigerators
Fan doesn't run on kenmore 5230 dehumidifier
sounds like the fan motor is bad most are not repairable new ones about 50$ dan
Jul 14, 2008 | Dehumidifiers
Clicking noise from compressor and fan runs 24/7
check the grounds to the ref. also check power to the ref. but it sounds like you have a floating ground the only thing else to mke comp.cycle is the relay which is on the comp. itself
Jan 08, 2008 | Kenmore 53092 / 53094 Side by Side...
Kenmore Elite refrigerator stops cooling - Relay keeps cycling
The compressor is locked up. Basically it is stuck. You can pick up at the local appliance parts store a hard start relay, Home Depot ,Lowes, or or those guys wont have it. Its not too expensive and is worth trying because your only other option is you need to replace the compressor. The part is called a kick start or hard start, the guy at the parts store will know what you are talking about. It is simple to connect and has the wiring directions on it. Sometimes this is all it takes. I have been able to get a stuck compressor to go by placing a short 2x4 on it and whack it with a hammer a few times. This is only a temporary fix though, as it will eventually lock up again, but emergency situation this saved the food. If the fridge has a fan back there make sure it works too, it may have been the original cause. Good luck.
Dec 26, 2007 | Refrigerators
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
634 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
