Spool not working and wont print test page - Computers & Internet
  • 148 Answers
Try to re install printer driver
Posted on Mar 16, 2008
HP psc 1100/1200 all-in-one stopped printing
Press and hold the cancel button and then press the start copy button release them together.
You should print a test page. No Test page an internal printer problem is likely!
If test page is good reset the spooler \. More than one way to reset spool file. Spool file controls transfer from computer to printer. Spool file a mess then printer hangs!!!
Method 1
a. Go to Start / Control Panel / Administrative Tools / Services
b. Select "Print Spooler".
c. While Print spooler is stopped, start it by double-clicking on "Print Spooler" and then click the "Start" button.
d. Verify that the "startup type" is set to "automatic".
Method 2
Create a new txt file
Type in exactly as the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Rename txt file killspool.bat
save on desk top
Double click off of desktop file to run
Next time printer hangs you can use this file again
Hope this helps?
Dec 03, 2016 | HP Office Equipment & Supplies
Web pages that I print go into queue and never print on my j4680
hi what you have here is that in the printer configuration you need to change the settings from spool to document. to print directly, you need to richt click the printer icon in printers and faxes, go into printer properties, then find the advance tab on there you should have a setting that says start printing immediatley make sure this is ticked or dotted,then that should be it, just print test page and you are done...hope this helps
May 31, 2010 | HP J4680 Office Jet All-In-One Printer
Kyocera printing very slow
Has it always been slow, or is that a recent development? At its fastest, the FS-2000 only prints 31 pages per minute, and that's for regular single-sided 8.5" x 11" with no special requirements. Anything else will (thick paper, longer paper, duplexing, etc.) will slow the print speed down.
One thing you can try to speed up the print speed is to change your spool options in the print driver. Go into the print driver (Control Panel > Printers & Faxes, right click on the FS-2000 and select Properties) and find where the spool options are located. Try selecting different spool options (such as waiting to send the job until all the pages have spooled, or sending it page by page) to see if any of them affect printing speed.
There are other options in the print driver's properties which could affect printing speed as well. Look around the different tabs and try changing some of the options to see if they make any difference.
You can also go to Kyocera.com and download and install the newest version of the print driver, which might speed up processing as well.
Hope that helps!
Mar 18, 2010 | Kyocera FS-2000D Laser Printer
I bought refilled catridges for my printer and it printed the test page fine. But will not print any documents from my files.All my connections are good and it even printed test pages from my computer what...
most of these issue are caused by either corrupt printer driver or busy print spooler.
You can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
have a great day :)
Sep 30, 2009 | Dell 924 All-in-One InkJet Printer
Vista Printer problems - Printer not printing Test page or docs
You may have to change the communication format called the "Spool format."
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 1200 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
If this does not help the situation, please describe any differences it does make.
May 14, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 2470 only prints 1 page out of 10 pages!!!!
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 2400 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
May 09, 2009 | Office Equipment & Supplies
HP photosmart C5280 document stuck in print que
Delete document manually from the path mentioned below:
1) Press windows + R an then type spool
2) Go to PRINTERS folder.
3) Delete the files present in there.
If not able to delete then
1) Open command prompt.
2) type "net stop spooler" and then delete the files
3)Again type "net start spooler"
Your stuck document is now cleaned. You can start printing your document again.
Mar 30, 2009 | HP Office Equipment & Supplies
HP deskjet 5550 printer not printing.
could be low on ink or toner. dont you just love that? itll print out a test page which is a waste of ink but wont print out anything else.
Nov 17, 2008 | HP DeskJet 5550 InkJet Printer
Hp laser jet 1020 has refuse to print
try to see if the printer will print anything by opening and closing the top door that leads into the toner seven times just open and close, if the printer prints a paper with lines then the printer is working now if the printer doesnt then try to take out the ink, paper and unplug the power cord and let the printer set for about three minutes..
If the printer does prints now it up to the printer spooler itself make sure thier isnt any jobs stuck in the spooler, if there is delete them and also reset the printer spooler, if that doesnt clear them out reset the computer, this will help it, finally when you have that done, do a test page by going into the printer and faxes and right clicking the laserjet 1020 going into properties, and in the general tap click on the test page this should print out a test page. if it does then your printer is up and running.
Jul 09, 2008 | HP LaserJet 1020 Printer
Prints part of the page then restarts the print
One suggestions would be to update the firmware of the Netgear Wireless print server Download the firmware for your print server from Netgear's website http://kbserver.netgear.com/release_notes/d102781.asp Instructions for upgrade are on the site! you can also try changing the spool settings, Set it to Print directly to printer RightClick on the printer click on properties and click the advanced tab. Change the spool setting to print directly to printer!! If this doesn't work kindly let me know! regards, babb
May 11, 2007 | NetGear WIRELESS PRINT SERVER 54MBPS...
Computers & Internet Logo
24 people viewed this question
Alun Cox
David Payne
David Payne
