I CAN DOWNLOAD MUSIC TO MY MIX MAX MP3 PLAYER BUT IT WON'T PLAY THE SONGS
***** don't
Posted on Apr 18, 2008
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
Highschool mucial mp3 won't download music from my computer
The nameless mp3 player that you have is probably not capable of playing DRM-protected songs. Double-check the songs that you have downloaded from Limewire, and see if the 3 songs that you ARE able to play are in mp3 format. If so, only transfer songs in mp3 format to the player. DRM-encrypted WMA's and iTunes (AAC) songs will not work.
-Tha Mp3 Doctor
Jan 06, 2009 | Jwin MP3 Player
Sync movies
Check out #7 at http://digiblue.com/customer-service/faqs/disney/mixmax/index.html
It has a PDF download with instructions on how to properly encode videos so that they will play on the Mix Max.
Jun 27, 2008 | Disney Mix Max Digital Media Player
Disney mix max problem
Connect your player to the USB port on your computer using the USB connector on the Mix Max. A 'MIX-MAX' window will appear in your My Computer folder which is the player's internal memory. To add more files and songs to your player simply drag and drop MP3 or WMA files from anywhere on your computer into the 'MIX-MAX' window.
For Windows XP, you can utilize Windows Media Player 10 software to convert music on an audio CD into MP3 or WMA format as follows:
Open the Windows Media Player 10 Browser, then click on the 'Rip' icon on the top tool bar. Insert a Music CD into the CD-ROM drive of your computer.
Click on the 'Tools' menu option at the top menu bar, then click on 'Options'; the Option setting menu will appear. Click on Rip Music and set the Rip music to the desired location on the newly ripped music (MP3 format or Windows Media Audio format). Adjust the audio quality as desired. When finished, click 'OK' to confirm the settings.
Click on the 'Rip Music' icon to start ripping the music to your computer.
When the music tracks are ripped; connect the player to your computer. Open the 'MIX-MAX' window and open the ripped music location window.
To add the transferred/ripped music file/songs to your player simply drag and drop the MP3 and/or WMA files into the 'MIX-MAX' window.
When the files are finished loading into the player, follow the 'Safely Remove Hardware' procedure as shown below.
Note: For Windows 98SE, Windows ME, and Windows 2000, please use the Windows Media Player 9 to convert music on an audio CD into MP3 or WMA format.
Downloading WMA files with DRM using Windows Media Player 10 (for Windows XP)
To download WMA files with DRM, follow the procedure described below using the previously installed Windows Media Player 10. Before beginning the procedure please turn the unit on and connect the unit to the computer as previously described.
Open the 'Windows Media Player Browser 10' and click on 'Sync'.
Click on the 'Sync List' pull-down menu to locate the music files you wish to download. Then make sure to click the box next to the files.
Select the Portable Device that you want to copy to from the right side drop-down menu. Click 'Start Sync' to start downloading the WMA file(s) with DRM to the Portable Device.
After finished downloading all the desired files to your unit, follow the 'Safely Remove Hardware' procedure as shown below.
Note: For Windows 98SE, Windows ME, and Windows 2000, please use the Windows Media Player 9 to download WMA files with DRM to your player.
Jun 16, 2008 | Disney Mix Max Digital Media Player
Puting videos on
The Mix Max isn't an MP4 player. It's an MP3/WMA audio player and WMV (Windows Media Video) player. Even if you do put MP4's on the same way you put your music on it won't even know it's there. The videos have to be in WMV format to begin with and then they have to be properly encoded for play on it.
May 27, 2008 | Disney Mix Max Digital Media Player
Disney Mix Max problems
The memory could be corrpt in the player. It some times happens so try reformatting the memory to clear it up. This will erase everything and then you can put your songs and stuff back on it. Here's a link to the manufacturers instructions on how to format the player.
http://digiblue.com/customer-service/faqs/disney/mixmax/06.html
Mar 21, 2008 | Disney Mix Max Digital Media Player
Disney Mix Match
You may need to update the firmware on the player in order to be able to play the Max Clips.
http://digiblue.com/customer-service/faqs/disney/mixmax/14.html
As far as putting songs on the player goes check out the FAQ's page on the manufacturers website. The specific FAQ for adding songs is here...
http://digiblue.com/customer-service/faqs/disney/mixmax/02.html
Mar 17, 2008 | Disney Mix Max Digital Media Player
Error free 4mb of space to build music library and disney mix max won't play any songs?
The memory may be corrupt and it can't read the music files correctly. Open your My Computer icon and plug the player into your computer. You should see a new removable disk called Mix Max appear. Right click on the disk and choose Format from the pop up menu. At the Format window make sure that the File System is set to FAT32 and click Start. At the next window click OK to proceed. You'll then need to add the songs back to your player but it should correct the problem. When adding the songs to the player again make sure that you leave at least 4 megabytes of space available so it can create the library file.
Mar 10, 2008 | Disney Mix Max Digital Media Player
How do i get videos on my mix max?
here it is, for those who nearly threw out those little things away, im not a techie but after 2 days i finally figured it out. whew! my 2 girls love youtube and music videos so for those who wants to get and play them instead of movies (the batteries on the mix max are not so good anyways) this is step by step, so be patient.
1. download youtube downloader (i usually download at cnet or sites you trust) to get those flv videos you like. (its quite easy to use and its free!!!)
2. download stoik video converter-(its free too) to convert those flv files to WMA, its quite easy to navigate but remember on the OUTPUT FORMAT choose wmv, i used WMV for ISDN 128, but...STILL in the output format click "edit profile" (scroll down to the end and you will see it) another window will pop out and change the frame size to 192x144 (mandymmof2 was right theconverted frame size should be at least the same size or smaller so thanks to him i was able to solve it)
3. go to windows media player or you can just open your converted video. drag it to the sync list, (but make sure your mix max is already connected and it says create a list to sync to mix max storage (internal/external whatever memory you choose to use)
remove and play...
FOR THOSE WHO DONT KNOW HOW TO DELETE SONGS/VIDEOS/FILES FROM MIX MAX .
you can delete it by clicking my computer, click disney mix max drive... the files you uploaded are all there to delete.
hope this helps!!
Jan 18, 2008 | Disney Mix Max Digital Media Player
How do you put music on a Disney Mix Max (512 MB) Digital Media Player
I have Windows Vista and the first time I plugged in the Mix Max it immediately downloaded the device drivers. I opened my Windows Media Player and it already recognized the player. I just transferred songs over walla they are on the player. Hope that helps.
Jan 03, 2008 | Disney Mix Max Digital Media Player
20 people viewed this question
 Grubhead
Grubhead
