Have a olevia t v lost channle #3 went threw set up and channle search also tried to add channle #3. tunner channle only will pick up channles 26 32 44 56 60
  • dorthvadder Mar 16, 2008
    thank you alls good.... moved the cables down in the back of TV No longer in the tuner we are now in composite with a better picture and sound. YOU are the GURU MAN...
  • 373 Answers
You could try bypassing the tuner and use the rca inputs if you have satellite or cable box that works this way. Hope this helps
Posted on Mar 16, 2008
SOURCE:
Wont program cable channles
Just to clarify .Are you hooking up through the tv or the analog tune?
Nov 23, 2012 | RCA HD52W59 HDTV Projection Television
I can get to the menu settings, go up to the auto channle search,,, but my tv won't do the search,,, what can i do ?
I have the same problem. Cable went out, hooked up an antenna and it scanned ok. Hooked up a diff amplified ant, worked the same. So watched videos. Next morning tuner would no longer scan or add channels. Now it will not even factory reset. Get to Auto Scan and it goes no further, cable or air.
Mar 28, 2011 | Syntax Olevia 537H Television
Tv suddenly shows no audio and no video for digital channles only yet all digital channles are detected durring the channel search
Sounds like you have a bad signal from the antenna or the cable. Unlike analog TV if the signal level drops below a certain level you loose the picture and sound completely. The fact that digital channels are detected during channel search does not mean they have a good signal. Try moving the antenna about.
Nov 29, 2009 | Olevia 237T 37 in. LCD TV
I need to know how to reset the tv (olevia model #lt37hvs) the tv is unable to scan the d-tv channles because of it being locked
Go to menu -picture- mode- power up - put it on home setting than all controls should be unlocked I think ur in showroom setting 99% of people who reset there factory settings get this problem
Jul 08, 2009 | Olevia LT37HVS 37 in. LCD HDTV
I can't find UHF channle 36
Turn plasma to analoque tv tuner auto search while xbox is connected and turned on. Auto tune will pick up uhf 36 channel .Flick chanelstill xbox chanel is viewable
Apr 19, 2009 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
Adding new channel to menu
some sets are hard headed and wont take a channle number unless it is autoprogrammed, might try autoprogramming set to see if picks up ch 60, good luck! :-)
Jul 08, 2007 | Olevia LT27HVX 27 in. LCD Television
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Ekse
