Tv problems I have a 32 in tv that will turn off after being on for 3 hours. It will also come on again in the middle of the night. I have checked the timer/alarm and it's not set. Please advise.
    Scholar:
  • 135 Answers
Hi there!
First of all make sure the buttons on the remote have not become sticky. If not that I would think that you probably have a temperature issue on the inside of the set. Could be Caps or loose solder connections. If not familiar with TV repairs refer to a repair technician. Good Luck, JUS004
Posted on Mar 16, 2008
Tv turns on in the middle of the night
perhaps you have set the sleep timer and it needs to be turned off .
Sep 04, 2016 | Televison & Video
Every night at 7.30 we dont have signal in our bloc.for 2-3 hours is not only my TV but everybody else have the same problem.After 2-3 hours all become good again.What can be the problem??
There are repeaters for the cable TV on the way and some need power to boost the signal.
Could it be possible, If the power to this repeater is drawn from a nearby post/outlet/house that is automatically programmed to power off for 2~3 hours every night ?
May 26, 2016 | Televison & Video
I have Sony bravia KDL 32 lcd tv, If I turn off the tv by remote after running it about one hour ,the tv will not turn on again by remote or side switch on the tv, I have to completely remove the plug from...
It is a failure of the power board voltage converter. Replace the power board and the issue will be resolved. It is not a difficult process if you are a DIY type pesonality I would go for it. Call sony for the power board, need model size and where it was constructed , Canada, Mexico or the US.
Good Luck Ed Pinero
Feb 02, 2013 | Sony 32 Bravia Lcd Kdl-32ll150 Hdtv
I have a vizio 32". I couldn't get it to turn on for several days, then switched out the power cord. It still would not come on, but I left it plugged in. After a day the logo came on, and then after...
To reset it you need to have it unplugged for about an hour, the sleep timer can be turn off.
How does the power supply look? no sign of bad caps and the voltages are OK. This can be the symptom of bad power supply or the main board EPROM got scrambled.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 12, 2010 | Vizio L32 32 in. LCD HDTV
Died, no light indicating getting power
Check ur power source outlet?Yes than ur power supply board,that the board ur a/c power cord go into it.That the power supply board,it dead.Take ur tv aparts and replaced the power supply board,ur tv will have power back and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 25, 2010 | Vizio L32 32 in. LCD HDTV
Proview LCD TV is turning itself off inconsistently.
I don't know about your particular tv, but most of the LCD tv's have a power off option that it will turn off after 3 hours of no activity.
Why it would turn itself off at 3 and 30 minutes is beyond me. But I did want to write so you can check your settings to see if maybe someone has programmed in some shutdown times or something.
Hope this helps at least some. Good luck!
Jul 31, 2009 | Proview PA-32JK1A 32 in. LCD Television
Acoustic Solutions TV Fault
I think you are looking at a power board problem. I had the same thing happen to a Vizio and I replaced the power board and it solved the problem. It could also be the input board but most likely the power board.
Thanks,
Ced
Jul 13, 2009 | Daewoo DLP3212 32 in. LCD Television
Tv turns off but will turn right back on
Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
RCA 32V420T (32 inch)
I think that vertical deplection IC of you tv set is shorted. Please check also the YOKE of the unit, its maybe grounded.
Sep 10, 2007 | RCA 32V420T 32" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
