Printer problem I have an HP DeskJet 850c and it's suddenly stopped printing. It will print a test page but when I try to print date it prints one line of rubbish... !!E!!&u600D!!g5W etc... I have tried disconnecting the printer and shutting down the computer and reconnecting everything again but to no avail. Please help
SOURCE:
map9966
  • 2351 Answers
SOURCE: My HP Deskjet F4140 was
Turn it off. Unplug the power cord from the printer & usb wait a minute. Plug USB in & than the power cable & turn it on. Next
Open the Printers folder.
Right-click the icon of the printer in use, and then click Open .
Click Printer on the menu, and then ensure that there are no checkmarks next to Pause Printing or Use Printer Offline . If a checkmark is present on either, click the menu option to remove it. If the menu shows Use Printer Online , click that option.
Posted on Feb 01, 2008
map9966
  • 2351 Answers
SOURCE: HP Deskjet 840c - Printing Emails
I did see you reinstalled your software) but please continue
It is important that you have that icon by the clock. Power off the printer by pressing the power button on the printer.
Please un-install your printer software through Add/Remove Programs within the control panel. Please restart the Pc after un-install is complete. Create a folder on your hard drive and name it, "HP DeskJet 840C". Go to this link listed below & download the printer driver software listed. When you save to disk you can choose where you want to save. Pick the folder you created. Save inside this folder. The HP driver (Will most likely be updated software). I promise, you will have a icon down by your clock when finished.
http://h10025.www1.hp.com/ewfrf/wc/product?product=59868&lc=en&cc=us&dlc=en&submit.y=4&submit.x=7&lang=en&cc=us
Follow the instruction in your manual for setup & installation.
If you using Outlook Express & you want to print or send through your printer the page should be set as 8.5x11". Orientation should be set to Portrait, unless you set this for A4.
Lastly, please turn off your anti-virus software during install & re-install. Just in case you come back to this thread!
please vote...
  • 51 Answers
SOURCE: HP Deskjet D4160
hi,
Ink-backup mode lets you continue printing with one print
cartridge when the other print cartridge has run out of ink.
Ink-backup mode allows the printer to operate using only one print cartridge. It is initiated
when a print cartridge is removed from the cradle.
Exiting Ink Backup mode
Install two print cartridges in the printer to exit ink-backup mode.
Cheers !!!!
Posted on Feb 15, 2008
  • 155 Answers
SOURCE: printer problem
I don't know how things work on a Mac, but if you're on a Windows based system, make sure the printer driver is installed on BOTH machines.
Matt
Posted on Feb 26, 2008
  • 537 Answers
SOURCE: 5650 deskjet printer
Check to make sure the ink is not dried on the output surface of the cartridge. If problems persist, try a non refilled cartridge to see if the problem can be reproduced there.
Posted on Mar 08, 2008
How to print a test page on hp deskjet D1341. I just installed a new cartridge and can't get back to the page that tells me to print test page
Click on Start - printersand faxes - right click on your printer - click Properties and then click Print test page.
May 18, 2012 | HP Deskjet D1341 InkJet Printer
HP Deskjet 3500 series, my printer keeps telling me that is is off when the light is green, keeps stating it is offline. When I installed the printer everything was fine, now when i print the printer...
Hi
HP Deskjet 3500 serie --
There could be a Software issue or hardware issue --
1) To check the software issue
Print a Test Page -- from the computer
2) To check the hardware
Press the Power button to turn the product on.
Press and hold the Power button
Open and close the front cover four times.
Release the Power button. The self-test will print
and it it is printing the hardware is fine ...
3) Then you can check by changing the USB Cable connection
Jan 01, 2010 | HP DeskJet 3520 InkJet Printer
I inherited the hp desk jet 850c, and I have no working instructions.How do I stop it from printing in the middle of a run.
One easy way is to remove the paper tray and then purge the print queue after a restart. You will also have to cycle you printer power for about 2mins to empty the print buffer after you have cleared the print queue.
Sep 28, 2009 | HP DeskJet 850C InkJet Printer
HP DeskJet 850c will not print colour
It could well be the printer head (the area where the cartridge locks into the printer) has gummed up contacts. Take a soft, lint-free cloth and wipe down gently wipe down the face of the contacts. Keep wiping until all residue is removed. Reinstall a color cartridge and then run the printer's software alignment utility (this is part of the software that comes with the printer).
Aug 27, 2009 | HP DeskJet 850C InkJet Printer
HP Deskjet 895Cxi suddenly won't print. Nothing happened, it printed perfectly one day, the next it didn't.
try control panel and diagnostic in printers and test page. also check usb wire pinched cat chewed ect
Jul 07, 2009 | HP DeskJet F380 All-In-One Printer
My hp deskjet 5150 will not stop printing
If you are using Windows XP
1. Click start then run then type in cmd then click ok.
2. Type in NET STOP SPOOLER
After that in the lower right corner of your screen you should see a printer icon. Delete the queueu
If that still does not work Unplug the power from the printer then wait for 5 mins then restart your computer and turn it back on.
Nov 11, 2008 | HP DeskJet 5150 InkJet Printer
Printer DeskJet 820Cse didn`t work
test page printing but doc files not printing....
HP DeskJet 6940
Sep 26, 2008 | HP Deskjet 6940 InkJet Printer
My HP deskjet D1430 isn't working
Do you have drivers installed for your printer if you do try going into printer setup and print test page if it will not it should give you a fault number so you can check on web for the fault and fix it
Aug 04, 2008 | Computers & Internet
Prints two bars across top only
uninstall the memory and try again
Jan 01, 2008 | HP DeskJet 5550 InkJet Printer
Open Questions:
Computers & Internet Logo
51 people viewed this question
Ekse
Alun Cox
