Kenmore Elite Calypso Washer agitator malfunction
The washer fills up abd the calypso agitator begins to agitate but then with in 10 seconds or so the agitator stops and the machine calls up an "FL" code
  • butrnipp Apr 03, 2008
    My kenmore Calypso just started doing the same thing, it first said Ld then it would run the water where the detergent is then flash FL and make a pretty loud noise like it wants to spin and agitate but can't. Any ideas on what these mean or how to fix the problem without having to call in a repair man or get a new one. I am 37 years old and on disability and don't have the money to do those things........
  • 28 Answers
You either have too much stuff in it or something that gets under
the agitator or it has a weak transmission
Posted on Mar 16, 2008
6ya staff
SOURCE:
No agitation. Humming noise
Check if the belt is fitted correctly and not broken.
Nov 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Stops in the middle of rinsing...leaves some water at bottom-
Calypso...The pumps fail often. They have redisigned one that theres not as many problems with, but if you still have the original, this is deffinatly the problem. As far as clothes getting stuck, the U-Joints wear out and cause too much play allowing things to get stuck. Total for this repair parts + labor will usually run about 500-600. There was a class action lawsuit for this machine and they no longer make it.
Mar 08, 2009 | Kenmore 24032\24036 Top Load Washer
Clothes stuck under agitator pan
You'll need to remove the agitator.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 08, 2009 | Washing Machines
Calypso kenmore elite water level low sometimes
something is clogging recirculating pump inspected both pump that should fix
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Washer calypso
Unplug your machine for 5 min then turn on spin to remove water. If water won't go you have a bad water pump. Code FL refers to a low water flow problem ( won't fill fast enough ) or old water still in tub.
Next you need to turn off the water ot the unit and remove the water lines. Look into the water inlets on the washer to see if the dirt screens are clogged and not letting water into you unit at a fast enough pace.
Your unit has a water level sensor and should agitate when full, but I believe your machine might be "timing out" i.e. not filling as fast as your unit expects so even though it doesn't fill all the way it begins agitating because it has taken too long to fill. Good Luck!
barneyluc
Oct 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
337 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
