Question about Philips 26PF9966 26 in. LCD Television
1/3 of screen loses sync
1/3 of right side loses sync anywhere from 20 minutes to 60 minutes. Screen gets garbled slowly before going to wide lines. I tried unplugging it and leaving for hours and holding the power button while plugging it in the the tech said, but problem came back.
  • Timdaman Jan 23, 2009
    Exact same issue TV runs for awile then starts slowly blur then lines on right 1/3rd of screen sometimes tapping on backside of tv brings it back for a minute or so and then back to the lines
  • godspeed247 Apr 06, 2009
    How do you fix this been trying have no clue
    Problem Solver:
  • 4 Answers
It sounds like you have a bad Inverter. we need to run TV in SAM and check for errors. Contact me.
Posted on Dec 31, 2008
We get garbled sound on new sharp aquos +Q TV 60 inch
If you are using an antenna for input, then you are probably partially losing sync with the signal. You may want to adjust the antenna or try a signal booster. If you have input from a cable box, check the HDMI cable, possibly replacing it with a new one. If you're using a cable box with RCA cables, (Composite or component inputs) then the problem is most likely with the cable box loosing sync with the channel feed.
Jan 29, 2015 | Sharp Televison & Video
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
Lost power when trying to pull out of a gas station, turned off ignition and after about a minute was able to get power to bike but clock was flashing as if it lost all power. Later that day while riding...
Hi Nsmith845, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Harley Diagnostic Codes 04 to Present
Sep 06, 2011 | 2011 Harley Davidson FXDWG Dyna Wide Glide
Double picture on start up
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the coursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of syncs.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
Good luck...
May 29, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Line on screen
if you found out how to fix or what is wrong with tv please let me no
Apr 07, 2008 | Fujitsu Plasmavision PDS-4233 42 in....
Philips 26PF9966 26 in. LCD Television Logo
121 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
