Question about Lexmark JetPrinter Z22 Color InkJet
Does not print from a document
Lexmark Z22 printer does not print from a document (letter typed), but does work fine printing from an e-mail message. Have followed the prompts on the "help" section, and it says to put a checkmark on the bi-directional area. When I put a check mark there, it still does not work-the checkmark goes away. What else can I do?
  • jdee600 Mar 16, 2008
    Thanks for trying, as I have installed the free driver download and still not printing from my typed document. Any other ideas?
    Genius:
  • 3,587 Answers
Maybe you need new drivers? they can choke from power glitches, too.
Posted on Mar 16, 2008
My lexmark z22 has never been used, has a new ink cartridge installed, but will only print test pages -- not what i want to save. please help
First you need to connect the printer to your computer with the supplied printer cable including the power cable.
You need to install the printer driver on you computer.
You may need to setup the printer preferences, eg. paper size etc.
You printer is now ready to print your documents. When you have opened an document such as a word document, to print this document click on file - print
Nov 13, 2010 | HP D1560 Deskjet Printer InkJet
Lexmark printer X5150 is printing color images but not typed font? Just installed new b/w cartridge...the color test works fine but can't get a letter to print out...page comes out blank
Try to see how you can restore the settings to default. There may be a setting to don't print text somewhere that got marked accidentally. Check your document type in the settings, it may be set to "picture" instead of mixed type document (I don't know what the setting is called, just that it's there) Also press the stop / clear button after printing an image to return to default settings
If this post helped, please vote.
Jul 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
Error message reads "34 short paper". What does this code mean and what can I do to correct it? Thanks
This error means that the type of paper that is configured in the printer is different from the one you have chosen in your computer to send for printing. Make sure that the paper size is the same in both places the computer program you are using and the printer. For example if I have a Letter size word document that I want to print but the printer has A4 configured then I will get the 34 short paper error but If I change the paper in the printer and the setting to letter size then everything should print fine.
Nov 13, 2009 | Lexmark C510 Laser Printer
Can not print a typed document from my Lexmark x2690
go to Lexmark.com click on support, enter model #, click on owners manual, scroll down to the picture that shows the lever that needs to be moved to letter.
There is installation software on the site you can download for free.
Most Lexmark printers lever is above and to the left of the paper tray
Apr 23, 2009 | Computers & Internet
I have a Lexmark Z22 and I am not able to print web site pages on the Internet. I am able tp print from my documents however.
just go to the start up menu an click on control panel then click classic view you should see printer then click on it then click add printer
Oct 24, 2008 | Lexmark Office Equipment & Supplies
Printer not printing
try a test page, first, please..computer disconnected from printer..
and go get fresh set of printer drivers here
Mar 17, 2008 | Lexmark JetPrinter Z22 Color InkJet
print the test page from properties if it comes clearly ,reinstall the microsoft office and check otherwise post the details of your printer
Mar 16, 2008 | Lexmark JetPrinter Z22 Color InkJet
New cartridge won' t print.
Was the cartridges lexmark factory replacements or was they generic replacement cartridges.
If they are generic cartridges you might want to buy lexmark cartridges because some generic cartridges will not work in some printers
Mar 03, 2008 | Lexmark JetPrinter Z22 Color InkJet
Both power & feed lights flash
Information gathered: Basically the printer carrier has stalled.
Lexmark documentation states that you should turn off your printer and wait a few seconds and turn the printer back on.
Restarting the spooler will sometimes do the trick as well.
Go to start, run
type: <cmd> without <>
Command prompt will open up.
Type: net stop spooler
The spooler will say it stopped successfully.
Type net start spooler
The spooler will say it started successfully.
Hope this helps!
Jan 20, 2008 | Lexmark JetPrinter Z22 Color InkJet
CANNOT INSTALL Z22
llucola:
The spooler service can be started following these directions.
Go to start
Go to run
In the open box type: <cmd> without <>
When the command prompt opens
type: net start spooler <Enter>
This should say that the spooler has started successfully.
Jess01: A driver is basically a communication device between your print device, which is your hardware "meaning can touch it" and printer software that is the language that your print device and computer can read. Your USB cable let's the computer know that your printer is connected. The software is needed so the printer has the language to be able to print what you tell it to.
If you have windows 2000 or xp.
Go to this website.
http://www.nodevice.com/driver/Z22_Color_Jetprinter/get31830.html
Scroll down the page 'til you find Lexmark Z22 Color Jet Printer
To the right you will see "download"
Click the link.
Scroll to the bottom you should see "Please enter verification code"
Type the code in and click "download"
Click save.
The software should then be downloaded to your computer.
Go to the location you saved the printer drivers.
There should be a setup file.
Click on that.
The printer should then be recognized and you should be prompted that the printer is going to print a test page.
Nov 05, 2007 | Lexmark JetPrinter Z22 Color InkJet
Lexmark JetPrinter Z22 Color InkJet Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
