my phone serial number is 50116881 and I have lost the manuel to program my phone and answering system. I am having trouble programing anything into it. Thank you for your help with this.
BettyPhone(4313349)
Betty
AnonymousJun 17, 2008
i have misplaced my manual for my answering machine . It will not accept messages when i call in to get them does not store themi have misplaced my manual for my answering machine . It will not accept messages when i call in to get them does not store them
You can't post conmments that contain an email address.
Panasonic KX-TA624/824 automatic Caller ID logging
How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824) System Programming:
In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
The Caller ID Indication button will light up only when the system has logged UN-answered calls.
Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
You can erase the entire Caller ID log by pressing Intercom, then 70**#
You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
1) the phone company needs to correct the caller id signal sent to your phone, or
2) the base unit is going bad and cannot proccess the caller ID signals.
Call the phone company and ask them to check your caller id coding first.
Since you neglected to specify the model of your Uniden 5.8GHz cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Click on a left side link of download manuels.
40000 series
DS4122-4
50000 series
cs5121-4
i6785
English
Not sure what series you have, but take a look at these manuels. found here :http://www.vtechphones.com/vtechui/support/manual_list.cfm#214
if not anyof these listed- there are many others to view and I know you'll find right instructions here!!
Let me know if this helped.--Stevie
5.8 GHz Digital four handset cordless phone system with digital answering device and caller ID
5.8 GHz digital Four Handset Cordless Phone System with Digital Answering System and Caller ID
i6785 - Spanish
5.8 GHz Digital four handset telephone system with digital answering system
english
i6786
5.8 GHz digital four handset cordless phone system with caller ID and digital answering device
i6786 - Spanish
5.8 GHz digital four handset cordless phone system with caller ID & digital answering system
Phone(4313349)
Betty
