Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
ESA 42" plasma tv not turning on
The other day i moved my plasma from one room to another, and everything seemed fine, the following morning i turned it on and everything was ok until the screen went blank. I could still hear sound so i turned it off and it never turned back on. now all it does when i try and turn it on is the power light just blinks a couple times then goes off. I can hear a relay clicking but nothing happens. Im assuming a cap. went bad, but after pulling the back panel off the tv to check the fuses on the power supply board all the cap's seem ok. None are bulged and all the fuses are in order, is there anything else i should look into before i smash this thing with disgust and buy a new one. thanks for any help you can offer.
  • 2 more comments
  • dssgod Apr 03, 2008
    I also have the ESA 42" plasma i bought from ebay. I notice that if the TV is warm it will not turn on. If it's cold and I turn it on, it will turn right back off and then on again. Weird. It looks like no one was able to answer the previous question.
  • Cardsstunt10 Sep 25, 2008
    I have the ESA 42inch plasma and I just hooked it up to my digital cable box... but when it scans for the tv input it says there is no input. I called mhy service provider and they tested everything and said that the tv is probably set on the air selection and not the cable for the tv input.... how do i change this...i cant find it anywhere under the menu selection???????
  • sammyandxavi Mar 05, 2009
    I have a 42" Esa plasma and the picture in it is actually cut over to the side. I have the left part of the picture on the right and the right side of the picture is pushed over to the left. Does any one know how I can fix this?
  • dado78 May 11, 2010
    hey guys i got 42 inch esa pdp4294lv1 tv and tv powers on got sound and red screen, Now after i check fuses and cables i got only sound. I can swich between chanels and hear tone but no picture. Is that a power supply failure or something else.Please help i dont wanna trow this tv in garbage......
I have a 42 inch plasma and I was watching tv last night on it and suddenly it turned off on it's own. I tried turning it off and on and nothing happened. Then I tried to unplug it and replug it and nothing. My remote does not work either. Anyone know what exactly happened? Did my screen blow or what? I hardly ever use the tv and I only had it on from 8:30 p.m. - 10:20 p.m. and it turned off. All the other tv's in my house worked fine - I checked them. Also, my dvd player and cable box is on the same power cord and both of them work. Any solutions or help would be most appreciated!!! Does it just need to cool down or did I burn something out? Help!!!
Posted on Nov 13, 2008
    Problem Solver:
  • 6 Answers
PDP4294LV1 Esa had made changes inside and used various differant parts.The silver colored units manufactured after Nov 2004 are worse than the oldes.I bought two defective units and both have diff guts inside.My advice--stay away from ESA,Vizio,Samsung.My unit started having V lines and sound.Like a dumbie kept turning off and on,now the set only--red off then green light on and blank screen. Best the units used as boar anchors. Stay away from any Plasma units--all junk and if you haveone still working--they produce high heat--notice that good ones have to internal fans--want to save yours--remove the back cover and hang as/is :^(
Posted on Nov 18, 2008
Esa and akai sound and no picture. I have fix one of these unit before by changing 4 of those square looking caps. the color of these caps are like red or orange. I am out of town for a few days. but when I get back home I will check and find the location of these components and the voltage capacity. hoping this info will help someone as much as this helped me. thanks jesse my email is jesse_diaz3000@yahoo.com
Posted on Sep 10, 2008
I have norcent 27 inch tv and suddenly it went dead, no power light turning on... help!!!!
Posted on Sep 09, 2008
    Sergeant:
    Champion:
  • 241 Answers
You have a bad power supply, is shorted so you need to replace it , do not turn it on or you will burn some other items and then the cost to fix it will increase drastically.
Posted on May 29, 2008
Does anyone have the user manual for the Esa 42" Plasma? I cannot find mine and am in desperate need for it. It will not recognize my that my DVD player is connected and I need some help. Thanks!
Akilah
akilahnisa@yahoo.com
Posted on Apr 14, 2008
Does anyone have the instruction manual for the 42" ESA plasma? If someone could scan and send it to me, I would be so grateful. I am trying to connect my DVD player and it will not recognize it. HELP! Thanks!
Ok im adding more info about this problem that i found out tonight, the question above is concerning my tv.i have the back off my tv and all i did was plugged the power cord back in to see if i could hear anything. as soon as i plugged it in the relay kicked on like it was trying to turn itself on, but i never hit the power button. then i noticed a heat sync on the power board was getting really hot even though the tv wasnt working, hope that info helps pinpoint the problem.
Posted on Mar 16, 2008
Tony hawk shred board will not calibrate on my xbox s console. tried it for hours everyway I can think, any suggestions?
My husband was ready to throw this game out the window instead of returning it because he was so upset...so nice for our 10 year-old on Christmas morning. Researched online and lots of people said putting two older batteries into the board with two of the new ones. We did that and also had to move the couch into the hall and then it finally calibrated!! Don't give up keep trying everything but the two older batteries helped. Once it was calibrated we moved the couch back and it seems to work fine. So far it seems like a cool game!
Nov 25, 2010 | Activision Tony Hawk: Shred
42" Panasonic Plasma does not turn on
Power supply board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 15, 2010 | Panasonic TH-42PX60U Television
My 42 inch plazma turns on but ther is no picture
my ESA 42" plasma tv turns on no picture and no sound.
Jan 30, 2010 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
My fan is not working picture fades out when over esa plasma tv
need to bring to your tv service center before it blows out and becames more expensive to fix only a tv tech will be able to fix it,,
Dec 16, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Everything seems to work but it is not collecting any water. Two years old, FDL25P11. Has worked perfectly until now, 25 qts every two days
Apparently the room humidity was too low (we were in a long cold dry spell) now that the rains have returned the machine works fine.
john
Dec 14, 2009 | Frigidaire Dehumidifiers
How do you get your ESA 42" plasma to stop sub-titles
Check ur remote see have CC botton,use that to turn it off.Go to menu find where said captioning turn it off.
Oct 14, 2009 | ESA ET413E 13" TV
Dead, no power
It sounds like ze power supply blew when it was being turned off. This seems to be typical of plasmas. Bad power supplys wont let the tv come on and will result in no lights coming on. Since there R no lights coming on, I would suspect the power supply first, followed by the power control board,. and circuit board. It may cost anywhere from $250 to $500 to fix.
May 14, 2009 | NEC PXT-42SX1B 42 in. Plasma TV
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
1,935 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
