My w969 washer dosent spin-dry as it used to at the purchase time in 2001. How can solve the problem- Thankyou
You should check that the pump is working well and pumping out fully,clean filters if required next is the belt ok not too much play tension ok not loose. next motor does it use motor brushes to operate some do not,if it does chances are will need replaced.You can find out simply if it uses brushes br trying to order some if they are available.Hope this help Happy Easter
