Question about Brother HL-2040 Laser Printer
The printer will not stay on
It was working fine, and now it just won't stay on. The green light will go on and the carriage positions itself, but then it goes off and I can't print.
    Genius:
  • 3,587 Answers
Hmm..try a new set of drivers through this link..
Posted on Mar 16, 2008
I have canon ip2000 printer, the screen shows error 5B00(The waste ink tank is full). the LED flashes, 1 Green(stable about 2 sec.), then orange/green, orange/green ..... 7 times(fast about 1/2 sec....
In case you haven't tried this before, here is a tip that should reset the printer.
Copied from site: http://www.cyber-ink.com/member-canon.html
To Reset ip2000 / 3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Also note that if the carriage is not moving as it should, it has nothing to do with printer drivers or your computer. It is an internal function of the printer and no external connection (usb/ethernet) should affect its operations.
Oct 16, 2013 | Canon PIXMA iP2000
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
Paper feed not working. green button and orange
I assume you mean that the power and resume lights are blinking. This signals a carriage stall. Open the top cover, if the cartridge cradle moves to the right, it isn't stuck and may be a one-time issue. If it is stuck, unplug the power to the printer. Open the access door and observe the carriage position. Clean any lint or paper pieces out. Remove any obstructions. Move the cradle and continue checking for lint, paper and obstructions until the entire area is cleaned out. If the print carriage started out on the left side, return it to that position to make sure the cartridges are back in the capping station. Look inside the printer along the cartridge cradle path for obstructions and remove any. Remove the rear access door and check for paper pieces, remove any obstructions.
Plug in and turn on the printer and see if the carriage returns to the left and reseats itself in the capping station. Close up the printer.
If this doesn't work, the printer may need service.
I hope this helps.
Mar 28, 2010 | HP DeskJet 5740 InkJet Photo Printer
Will not print. power light flashes green and orange. opening cover does not allow carriage to go to the cartridge change position.after many attempts to print, there is ink leaking from below the...
It goes to damage Ink absorber .Many ink absorb this pad.You must be reset it self or any workshop.if itself
1.Press power button and resume button realize resume button and press 3 time then go to power button.
Feb 12, 2010 | Canon i350 InkJet Printer
Epson DX6050. System locked with E-02 showing. All lights are showing green but apart from the ON-Off button nothing works. How do I get the print head to the correct position to change the cartridges?...
Read printer manual for detail of status E-02. Turn on printer, imediatelly unplug power chord while carriage moving. Unplug USB. Move carriage by hand to replacement position.
Sep 10, 2009 | Office Equipment & Supplies
Hp deskjet 882c printer carriage is stuck
Hi first of all you need to make sure that everything is in good shape on the carriage and the cartridge holder,
also check if you have any broken plastic pieces in the printer.
you mentioned the reset a well
was it a partial or a semi full reset
another thing which we can try is
1>take out both the cartridges
2> unplug the power cable while the printer is on
3>press the power button for 30 sec to remove the static
3>replug the power
now let the printer lights blink prompting you to put the cartridges
4>put the black cartridge first
some Hp printers work on single cartridges as well.
5>see if you hear the same grinding noise again
6>try cleaning the rollers with a little damp lint free cloth
7>try putting the color cartridge
make sure that the cartridges snap inside properly.
8>see if the problem persists
Jun 15, 2009 | HP DeskJet 882c InkJet Printer
Canon MP780 print head won''t move automatically
THis may be a stupid suggestion but normally, you must open some housing part to force it to center for service or cartridge replacement and the closure of the same access part causes the carriage to return to its hiding place.
With the power on, gently push against the carriage in either direction. If it doesn't fight with you, the belt may be either off a pulley or torn.
Dec 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Printing problem with model z33 lexmark printer
Replace Printer - there is no repair option.
May 26, 2008 | Lexmark Z33 InkJet Printer
Data light and Cartridge light stays on
Clean off cartridge contacts on printer carriage where carts sit and contacts on cartridges-if they sit for long periods of time they clog up.
you will probably need new cartridge{s}
start with black and go from there.
we use alcohol.
Apr 02, 2008 | HP DesignJet 450c InkJet Printer
Orange cartridge light error keeps on blinking!
clean the carriage home
check the data cable for the carriage home
check the media sensor on the left of the plotter media bar
Mar 12, 2008 | HP DesignJet 450c InkJet Printer
Brother HL-2040 Laser Printer Logo
24 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
