Question about Teac PD-D2380 5-Disc CD Changer
Spindel problem? I finally took the time to look at my CD player. The disk does not spin; the silver piece the rises which, I guess, should spin the disk does not do spin. SO - I guess the problem is a bad spindle motor. Being that I am rather inept at repairing mechanical/electrical appliances, is this a simple thing to take out and replace? If so - how?! Since the machine already is broken (and was free) I am of the thought that I cannot break it any more! And so will try to fix it. Thanks for your help.
My problem is that the turn table keeps turning and it not playing the disk
Posted on Dec 28, 2008
  • Anonymous Dec 28, 2008
    HI THE WHEEL DROPS DOWN AND AND DOES'NT COME UP
    Sergeant:
  • 395 Answers
95% of the time it is not the spindle motor it is the optical pick up assembly. the optic cant see that there is a disc in place it doesn't spin. look at the eye does it move up and down when the disc loads? this does not mean the optic still can't see the disc but clean the lens first. a weak laser will not be able to see the disc also. most of the optical pickups will last only 4yrs to 6yrs of normal use the problem most likely is the optical pickup.
Posted on Mar 16, 2008
SOURCE:
Teac CR H100 CD player just clicks when I press play and if it plays, it stops very soon. Is this teminal
it sounds like it is the motor that spins the disk most likely not worth replacing unless the unit has high sentimental value to you
Sep 23, 2010 | Teac Audio Players & Recorders
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
Cd player is not working. One day it was working and next day it wasn't. I guess a button was pushed and now we can't figure out. Cd player will not read or play cds
?: Does the cd spins? If it does the optical eye that reads the cd could be dirty. Clean the eye with cd lens cleaner. If the cd is not spinning the motor could be bad. Also some cd players can't read certain disks because of the density of the disk. Make sure you read the manual to see what cds are compatible with your boombox. I hope these solutions were helpful.
Good Luck
George
Mar 01, 2009 | RCA Audio Players & Recorders
Emerson 3 disk CD player - CD spins - message
im not sure what toc read means, my cd player says that im guessing it means its loading, any ways take the d player apart an clean the lens wit a cuetip that should work, or the cds may be to scartched to read
Oct 15, 2008 | Audio Players & Recorders
Pioneer PD-F907 CD wont play most of the time
MOST LIKELY IT SOUNDS LIKE THE MOTOR THAT SPINS THE DISC - NEEDS REPLACING
Jun 26, 2008 | Pioneer PD-F907 CD Player
Disk error
can you hear the cd spin?
more times than not the laser is bad.
Oct 18, 2007 | Sony RDR-VX525 DVD Recorder/VCR
Check disc message
Sometimes the Spindel Comes lose from the Platter,Put one small drop of Super glue,Where the Center pin on the Platter is let dry for ! Hour,Should restore full operation...
Jul 19, 2007 | Zenith DVP615 Portable DVD Player
PD-F505
try a lens cleaning cd,if this doesnt work is more than likely optic (laser) faulty as laser has to focus first before spinning disc.if it cannot focus disc will not spin..
May 15, 2007 | Pioneer PD-F505 CD Player
Teac PD-D2380 5-Disc CD Changer Logo
256 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
