Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
WASHERS WILL START
GE HARMONY STARTS AND THEN SHOWS THERE IS A PROBLEM WITH THIS UNIT.
  • 725 Answers
GE Profile Harmony
1 press power ( to wake up washer)
2 press Home ( it may already show HOME)
3 press HELP
4 press and hold MY CYCLES and BACK (for 3 to 5 seconds)
the service mode diagnostics screen will come up
it will show what errors are recorded..( if more button is displayed then also go to next list)
be sure to write them down exit will clear the codes and run a test
Let me know what the errors are I can help..
Posted on Sep 13, 2008
  • 1 more comment
  • Moe Dakar Jul 28, 2013
    Hey Franklin, I came across your advice and it was very helpful. You had mentioned letting you know what the error was and you may be able to help. If that still stnad would you please give some further advice on an error that reads something to do with the motor. Unfortunately each time I go to turn on the unit, my washer runs through a test cycle and concludes with no option to re-run the diagnostic. What had happend was that my son had overloaded the washer with heavy blanketsand washed on a "sheets" setting. An error came up towards the end of the spin cycle and the washer had not drained any on the water. It seems as though the interior bin doesnt spin anymore. What do you think I can do? Thanks!
  • Franklin Ouchida
    Franklin Ouchida Jul 28, 2013
    hi Moe.I have work on the machines... If it will not drain it will not spin... if you can let me know what your error code is I can help..please let me know how much you are willing to do yourself?
  • Eric Stadnik Oct 07, 2013
    Hello Moe, I have same issue as Franklin (above) the error message says, "The motor is not rotating properly. Check & replace if necessary." with 2 codes at bottom of screen: "MAIN: MV 1.0A, and INVT: V 01 08" after resetting, also received a next message of: "Serial communication link between MAIN PCB and Inverter PCB is down." when starting, there is a hum where there is usually agitation. The unit has worked great for several years - this is the first problem. How can I determine if it is the motor or just the serial com link, or something else? thanks, Eric
My Ge Harmony Dryer sometimes will not spend. It heats up but will not spend at times.
Try manually start the dryer. Take a piece of tape and tape the switch on the door. Then take one hand turn the drum and press the start button at the same time. If is starts then then you have bad motor.
May 18, 2011 | GE Profile Harmony DPGT750EC Electric...
My ge profile harmony washing machine has a message that says "a problem has been detected with this unit."
Washers - Harmony Washer Error Message or Code
The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature.
"A problem has been detected with this unit" will be displayed on the screen.
The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
GOOD LUCK. TIMOTHY DO 714-334-1998
Aug 04, 2010 | GE Washing Machines
The compressor on my ge ASH10ABS1 window air conditioner starts and operates fine but won't shut off even when the temp control is lowered. What's up?
when attempt to I power up my GE window unit, a message
' E1' shows, and the unit does not start. what is it telling me ??
May 19, 2010 | Heating & Cooling
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
Have a message on GE Profile Harmony washer that say " a problem has been detected with the unit" help?
Solution:
Jan 15, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
GE Harmony Elec. Dryer Blower Stops working or won't start up
Do this.
press "Home"
press "Help"
press both "My Cycles" and "Back" at the same time and hold them until service mode pops up.
It will tell you what's wrong.
Jul 22, 2009 | GE Profile Harmony DPGT750EC Electric...
My ge profile harmony will not spin and drain
I AM NOT A MECHANIC (THOUGH I WISH I WERE), BUT IT SOUND LIKE YOUR BELT OR MOTOR COUPLING. I DON'T WANT TO TELL YOU WRONG. I AM NEW AT THIS STUFF. I HAVE BEEN AROUND WASHERS ALL MY LIFE TO KNOW WHEN THEY BREAK DOWN AND NEED TO BE REPAIRED, BUT MY DAD (WHO DIED IN 2006), SPENT MOST OF HIS LIFE REPAIRING MINOR PROBLEMS ON WASHERS. GOOD LUCK.
RODNEY
Apr 29, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony Electric Dryer - Starts out heating but then screen says SENSING
nicknames, usually with long dry times I suspect a pinched or clogged vent. Make sure you check that first. You can do a test to check the moisture sensor. The 2 sensor bars will be on the inside of the drum just below the vent cage. Press the home and then help button. Next press and hold the help and start/stop button for 3 seconds. On a dry sensor, you should see a voltage of approx 4.75 displaying. Now get a wet rag and hold them across the 2 sensor bars. You should see the voltage drop to about 1.0 volts. If it does this your sensor is ok. Check the vent and this out first and we will take it from there. Catriver.
Dec 03, 2007 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
616 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
