Question about Lexmark JetPrinter Z22 Color InkJet
Printer not printing
I have typed a letter in Microsoft Word and when I click "print", the paper goes through the printer and sounds as if it is printing, but nothing is printed on the paper. What can I do to correct this?
  • z70x7 Apr 10, 2008
    Help!!! My Lexmakrk z22 Printer is not working. It sounds as if it's printing all details of my documents, then the pages come out blank. Please help. I don't know how to fix this problem.
  • Anonymous Jul 01, 2008
    well my Lexmark Z22 printer won't print. the problem communicating with the printer sign comes up and, it dosen't even make sound. Also everything is plugged up.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 194 Answers
Print the test page from properties if it comes clearly ,reinstall the microsoft office and check otherwise post the details of your printer
Posted on Mar 16, 2008
6ya staff
SOURCE:
Load try1 plain letter error on display screen appears on lexmark e342n
If printer is connected to a network, type the printer IP address into the address field of your Web browser. Click on Configuration and select on paper menu and make you have the correct settings. Make sure you selected the correct paper source and paper type.
Make sure on your application, the print settings matches with the printer. Check the print settings of the application that you are using. For example if you are using Microsoft Word, you need to click on print and click the properties button and go to the paper tab.
From the Paper Tab window you can modify the Input options like paper size and the source (paper tray). You may click on the drop down and select "Automatically select" for paper tray and select "Use printer settings on paper type and then click OK.
For further assistance, please contact Lexmark Technical Support.
Jun 01, 2011 | Lexmark E342n Laser Printer
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
Please teach me how to use my HPF4185 to print envelopes. Thanks.
Hi
Use the product software, also known as the printer driver, to change the print settings for your envelope size and type. Then, use the Envelopes and Labels tool in Microsoft Word to select your envelope size.
Step one: Adjust the print settings
-In Microsoft Word, click File , and then click Print .
-Make sure that your product is in the Name drop-down list box, and then click Properties .
-Click the Features tab, or the Paper/Quality tab.
-Select an envelope size from the Size drop-down list.
-If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
-Select Custom from the drop-down list.
-In the Custom Paper Size dialog box, type a name for the new custom size.
-In the Width and Height boxes, type the dimensions.
-Select the unit of measurement, and then click Save .
-Click OK to close the Custom Paper Size dialog box, and then click OK again to close the Properties dialog box.
NOTE: You must exit the Properties dialog box to apply your changes.
Open the Properties dialog box again, and select the new custom size from the Size drop-down list.
-Select the paper type.
-In the Paper Type or Type is drop down list, click More .
-Click the desired paper type, and then click OK .
-Select the paper source from the Paper Source drop-down list.
-Change any other settings, and then click OK to close the Properties dialog box.
Step two: Set the correct envelope size
-Set the correct envelope size in the Envelopes and Labels dialog box before printing envelopes.
-In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
-In the Envelopes and Labels dialog box, click the Envelopes tab.
-Click Options .
-From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
-Click OK , and then click Close to close the Envelopes and Labels dialog box.
-Click File , and then click Print to print the envelope.
NOTE: When you finish printing the envelopes, return the paper size and the paper type settings to the defaults.
Regards
Riztech
Oct 30, 2010 | HP Deskjet F4140 All-In-One InkJet Printer
Printer selects tray1 as default tray. how can this be changed?
Tray 1 by default is set to any size, any type, which means that no matter what you print, it will pull from tray 1. You can change that by setting tray 1 for a specific size and type, such as 8.5" x 11"(Letter) and Plain paper, and then going into the print driver options (Control Panel, Printers & Faxes, right click on the HP 3550 and select Properties) and under the paper input tray, change it to either tray 2 or 3.
Jun 09, 2010 | HP Color Laserjet 3550 Printer
I can't print a letter from my microsof office word program. the printer works but when i try to print t6his letter i doesn't Hp photosmart c5280 all in one printer scaner copier , ineed and up date...
Check if the correct paper size is selected according to the letter size that you are trying to print,select custom size and give the specifications of the paper manually.
Open Solution center software on your PC, click settings>Printer settings, in the feature tab you have an option named Paper type, select plain paper and then click ok and close window and Solution center and try to print.
Sep 27, 2009 | HP Photosmart C5280 InkJet Printer
Whenever i change paper size from A4 to letter,
Don't set by using the "Print" option.
Go to [Start]
[Printers and Faxes]
right-click on the HP printer entry
! Don't select "Printing Preferences"! from there
Select [properties]
Select [Advanced] tab
Select [Printing Defaults]
[Advanced}
(I know, the screen looks the same, but it functions differently this way)
Change paper size to "Letter"
[OK, OK, OK]
*done*
Sep 25, 2009 | HP LaserJet 4350 Printer
It will not print any thing except a test sheet
Try it on another computer. I think your computer contains virus.
Jul 08, 2009 | Lexmark Office Equipment & Supplies
Paper jam when trying to print envelopes.
You need to make sure that your print sriver setting match the setting on the printer itself.
If setting are changed on the printer itself to envelopes then when you go to print click preferences button on print screen and look for a place to change paper type (usually defaulted to letter size.) Change paper type to envelpoes and click ok. Click ok again on print screen and it should print correctly.
Paper types must be configured the same on the device as well as the print driver installed on the computer.
Hope this helps
TankMurdock
Mar 09, 2009 | HP Photosmart D7260 Printer
Letter size envelope does not fit into the paper holding tray
Hi cmwww920,
Usually letter envelopes are insert long-way into your printer. I recommend using the Microsoft Word envelope wizard to print Sender and/or Recipient addresses on envelopes. Here's how it works:
1) Launch Microsoft Word.
2) Click Tools > Letters and Mailings > Envelopes and Labels...
3) Type in what you want to see on the envelope.
4) The default feed direction is shown in the lower right corner of the dialog box. To change it, click Options and select the Printing Options tab. Adjust the settings as you please.
5) Click OK to exit the Options Dialog Box
6) Click Print (in the upper right corner of the "Envelopes and Labels" dialog box.
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
Keep getting "11 load letter in tray 1" message
Are the print jobs being sent to printer all the same page size?
Are they all print jobs sent letter page size and your printers cassettes are set for A4 or something?
Your printer is asking for letter size paper, because any paper it has is not set to letter  and document that it is trying to print has been sent as that size.
Check what options you have on print driver on pc as far as Tray defaults, paper type and size settings
Check printer settings via its keypad as to tray defaults, paper size set for each tray and paper type, some printers have paper size switchs on their trays too.
Oct 26, 2007 | IBM Network Printer 12 Laser
Lexmark JetPrinter Z22 Color InkJet Logo
61 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
