Always toggle through the tv/video button to make sure your on the correct source. usually the menu button is pressed, then the up/down and left/right button navigate the menus.
make sure your vcr or satellite receiver is on and set to use channel 3
press the menu button on the tv untill you get to channel settings, look for auto channel setup or search. If the signal is coming through on ch3 and the cable is correctly installed from the source to the tv, this will find the broadcasting station and lock onto it.
If you dont have a menu button on the tv , it could be hidden behind a small door,
if still no menu button, you will have to find a replacement remote to set the channels.
