Question about Black & Decker GT300 Coffee Maker
My new GT300 won't prime.
When I set up the new machine, I hit the clean button like I was told and it blinks a few times and switches over to 7 and 9 oz buttons blinking. I unplugged and plugged back in quite a few times, and even tipped it upside down to empty the little water thingy and still nothing. Should I return it for new one, will the new do the same thing? I bought my old one for $4.00 at a garage sale and it still works great.
  • 1 more comment
  • cdphx2k5 Apr 19, 2008
    Same problem - only the one I purchased was the last one at the store. This problem seems very common and nobody has a solution.
  • ABZsilch Aug 13, 2008
    I have the same problem. Called support and they told me to "forcefully" push down the water reservoir... didn't work. They also said to do a system reset (fill water tank, plug in, push 7oz button, push stop, unplug, wait 15 minutes, plug back in) This also did not work.
  • Anonymous Nov 22, 2008
    Having same problem. Tried calling customer service not open on Saturdays.
I fixed mine! The idea here is to help fill the tube inside back up with water. The unit may need a little help to get the suction going.
Preparation: Set the unit so you can easliy reach the back side of the unit. Fill the container with 7 - 14 oz of water and have it nearby. Place a cup underneath the coffee drip container in the front. Have another small cup of water handy.
Process: Plug in the unit to an outlet. Hold as much water in your mouth as you can. Press the CLEAN button on the unit then put your lips over the water inlet valve on the back of the unit. Force (blow) the water from your mouth into the inlet valve. You should begin to hear the unit pushing the water through. Place the water container over the water inlet valve after you have released the water from your mouth. The unit should continue to empty the water container. Now, you just have to fill the water container and make a cup of coffee.
This is the same procedure I performed to get mine going again; I am not trying to make you look like an idiot.
-Richard Barrett
Posted on Oct 13, 2008
SOURCE:
I have a Nespresso Lattisima and all four lights are blinking four times in quick succession and nothing is working. I've tried emptying it out and it's done that, but still the same problem.
Your machine has almost certainly entered the water quality mode. (Water hardness setting). This is very easy to fix. Switch machine off. Before switching back on press and hold any off the following buttons: Latte Macchaito (top right) for soft water, Cappuccino (bottom right) for medium water or finally both of them for hard water. While holding the correct buttons switch the machine back on BUT hold for approx. 10 seconds or until all lights stop flashing, (APART FROM THE BUTTON YOUR HOLDING). This will reset the machine and you're good to go. Regards Coffee Engineer!
Jan 17, 2013 | Nespresso Lattissima 660.R
Wagoner Procoat Airless Sprayer without manual. Won't prime.
One cause for this is that one or both of the check balls in the piston are frozen in place. This can be caused by drying paint on the check balls or seats or, as is the case many times in our area, if you did clean the machine well with water without any airless conditioner in it, sometimes the water dries and leave behind minerals that 'lock' the check balls in the seats. Set the machine up in water and turn it on to prime. Using a hammer hit the pump head where the piston is working fairly hard. You are trying not to break anything but knock the check balls loose. If they come loose and water starts cycling through the system, let run a while to wash anything out before switching to paint. If this doesn't work, you may have to take the head apart to see why the check balls won't free up. It could be because of peices of dried paint that won't come loose by themselves.
Jun 16, 2011 | Garden
I have just been given a Black & Decker 'Mr Cuppacino' with no manal, how do you clean it?
clean it with vinegar. run it through a few times and then put clear water in it and run that through it a couple of times
May 05, 2011 | Black & Decker GT300 Coffee Maker
I press the desired amount or the clean button and both 7 and 9 ounce buttons flash. It wont do anything
With the GT300 you can service the unit. You will need a flat head screwdriver, preferably a low quality one, that will need to have a small spot filed out in the very middle of the flat head area to remove a few special screws that are common to these appliances.Luckily it is very easy to modify a flat head screw driver to remove the area necessary to make the tool work well enough to remove the special screws. After that, you will need a phillips screw driver as well. Remove all the screws, some are hidden underneath the plastic grip pads on the bottom as well. You will observer a tin can heater, and a priming pump (white) and an invensys ******** pump (red). The invensys pump (CP1, CL1) is very easy to service and this is what you will find the problem is 99% of the time. Just unscrew the plastic ends (you may need a wrench) on the invensys pump. It will come apart, be careful to keep all the pieces, they will spring apart like a jack in the box if you are not careful. Get all the pump pieces where they are moving again and then put the pump back together. There should be two metal rings with a plastic ring between them. You may have to plug and unplug the unit a few times and get out any excess water before getting the system primed and running again.
Dec 24, 2010 | Black & Decker GT300 Coffee Maker
How do I set the time on the Sony CDX-GT300? Car came with the radio but time needs to be set.
http://www.usersmanualguide.com/sony/car_audio/cdx-gt300 and click on the user manual. Or www.docs.sony.com/release/CDXGT300.pdf.
Press and hold the select button until setup display appears. Then press select button until clock-adj appears.press dspl. Use the volume control to adjust hour. Press dspl to change to minute or back to hour. Press select when done.
Jun 21, 2010 | Sony CDX-GT300 CD Player
My kenmore dw just stopped running thru cycles except drain
Hello, With the information you supplied I'm going to assume the light is blinking 7 times and pausing then blinking 7 times and so on. With the door cracked open hit the following button combination: -high temp wash
-heated dry
-high temp wash
-heated dry Then close the door and hit cancel. The pump will run for a few moments and then you should be all set. Hope this helps Mike
Nov 19, 2009 | Refrigerators
Blak & Decker Home Cafe GT300 won't stop untill water is gone
Jul 25, 2009 | Black & Decker GT300 Coffee Maker
''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Apr 01, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Not working
Press the High Temp Wash then the High Temp Rinse, 3 times in a row, quickly. This resets the microprocessor. The unit will go through a short set of tests and then be ready to use again.
Jan 28, 2008 | Whirlpool 24 in. DU1055XTPS Stainless...
Home Cafe GT300 Black and Decker- won't work, brand new
I have the GT300, and it also started having problems with the 14oz and cream loight s blinking. After trying the unplug and replug thing I gave up, I came back to it the next day and it started working again so I just kept running it over and over until I got it to fail again when I opened the lid and put a pod in to make a cup of coffee. It wouldn't work again so I unplugged it and set it back up and held my hand on the lid and applied a little pressure and it started working again, so far with a little preesure applied it still works. My guess is there is a switch that dosen't make as well as it should, you don't have to hold the lid down during the entire brewing cycle just long enough for it to get started. Good Luck
May 07, 2007 | Black & Decker GT300 Coffee Maker
Black & Decker GT300 Coffee Maker Logo
351 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
Pierre Laplante
eyecam
Sheldon Dedek
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
