Question about Haier XQ8M22-C PORTABLE TOP LOAD WASHER
Haier front loader 1400 spin
It only spins now and again and when it doesnt it says end unb
  • 3 more comments
  • Anonymous May 01, 2008
    I have the same problem, I tried with many programs and always the same UnD flashing at the end
  • Anonymous Jul 01, 2008
    i just got my hw-c1460 today and it won't spin at a good speed!! It just gives the unb error after an 11 min spin cycle- even when nothing is in the machine!
    Did anyone have any luck with solving this problem...?
  • Hilaryrock Jul 13, 2008
    Hi I have a similar problem on my new HW-C1260TVE-U washer. I have tried several washes an spin cycles / speeds. The washing machine will not spin for mor than 5-10 seconds during the spin cycle and ends with the UnB error. There is no problem with the pump or water as the washer is draining before it attempts to spin. The macine is on level ground and stable. Does anyone have a solution for this error
  • marvinsmate Jul 15, 2008
    Hi, I have same washer and same problem. Was told to check drainage pipe, tilt if forward, check the filter at the front. It still only spins if it feels like it. Can anyone help?
  • marvinsmate Aug 08, 2008
I also had this problem, I followed the advise above with no luck, so tried to spin the drum by hand. The drum span easier than normal but there was a dragging sound so I took the back off to find the belt had come off the drive wheels. Belt replaced all tightened, back on and working machine
Posted on Jan 30, 2010
I had this problem too. Its basically a blockage in the pipe! Open the filter on the front and release the water which will go all over the floor!!!! put back on and see if its fixed. If this fails try to take it off again and blow hard down the waste pipe and it will unblock the filter. Its a strange fault and I sell washing machines for a living!
Posted on Jan 20, 2009
  • 105 Answers
Check to see that pump is not blocked stopping water getting away quick enough
Posted on Mar 16, 2008
Get rid they are ****
Posted on Jul 12, 2008
My Haier washer can not rinse and spin
My Haier front loader can not spin out correctly it's to loud and shakes back and forwarder spinning out on the wrong load because the size load button is struck in side the machine and won't pull out.
Sep 29, 2013 | Haier Heating & Cooling
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
HALF LOAD
the machine will not spin for you if you try to do a small load , you will only get UNB , this is why you have no Half load, hope this helps
Feb 22, 2009 | Haier HWD1000
Spin cycle error - UNB
Haier have had one or two problems with there spin,
option 1 make sure the machine is balanced perfect [no rocking at all ] use a level on the machine [ truly ] it works.
option 2 you can not wash one item [ underload the machine or overload the machine this will give same result UNB .
option 3 if you have had the machine a few months and this has just started [ clean the armature on the motor with emery cloth and a quick spray of W D 40 please plug out the machine first
0161 355 8254 if you need help , good luck
Feb 17, 2009 | Haier HWD1000
Dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Jan 27, 2009 | Haier Washing Machines
Spinning but clothes are still very wet ,
unb means unbalanced i had the same problem and i called comet where i got it from and they replaced the chip board and ever since then its been fine i hope this helps you
Jan 27, 2009 | Haier XQG50-QF80 Front Load Washer
What does unb at end of wasn after it says end??
unbalanced - means it didnt spin properly due to clothes being unbalanced. Its supposed to stop the machine damaging itself - but its just a pain. Need to fill the machine with a full load to avoid this. Dont suppose your machine's a Haier??
Jan 03, 2009 | Washing Machines
My haier washing machine doesnt work properly
get rid of it. I had two of these that did the same thing. people all over the internet are suffering with haier washing machines! They are utter rubbish and I will never buy haier again!
Jul 30, 2008 | Haier 14.3 lb. Washer/Dryer Combo
My Haier HW-C1460TVE-U washing machine was installed this morning did the empty cycle first then did a load of towels worked perfectly did another wash Err code Unb came up. Got sprit level and checked...
Have been to one of these machines today. UNB will still show even if the machine is empty. I think the feedback amplifier on the main PCB is at fault. If I have any luck with it I'll post another message
Jun 29, 2008 | Washing Machines
Haier XQ8M22-C PORTABLE TOP LOAD WASHER Logo
530 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
