Question about Dryers
Maytag dryer won't keep running
Push the start button and have to hold it to keep it running but it still shuts off in a few seconds. Maytag dryer model de412 series 07
  • mhiggy30 Apr 10, 2008
    I gave up on this dryer as it was 18 years old and I was tired of doing constant repairs. Thanks
    Sergeant:
  • 236 Answers
Poss the starter relay.
Posted on Mar 16, 2008
6ya staff
SOURCE:
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Maytag Centennial Gas Dryer: Only runs in "Air Fluff" setting. If any other setting (Normal Dry / Timed Dry) are used the dryer shuts down immediately. If I force the dryer to run by holding down the start...
Hello Kevin;
My name is Peter. I am a retired field service appliance technician.
When you run your dryer on fluff you are not using heat. The burning smell is when you use normal dry and the lint starts to burn. This will shut your unit down.
You just need a good cleaning. Nothing major. Send me your model number and I will help you.
Dec 11, 2014 | Maytag Dryers
Intermittent Start (expanded explanation)
Lint will jam the start/run switch on the motor. Vacuum out the motor real good and check that the switch moves freely, and all the wires to it are plugged in good.
Nov 30, 2013 | Maytag Dryers
Intermittent start
Not a thermo fuse sound like motor is struggling.
May just need taken apart and cleaned
Maytag dryer sounds like it is going to start but wont start
could be that the belt is cut off , of the the puleys are jam .. does it make a big noise ( squeeky noise
May 12, 2017 | Maytag PYE2300AY Electric Dryer
I have a maytag Neptune NDE3000AYW and the dryer turns on, runs for a few seconds and stops. took it apart and cleaned all the lint and dust. after a while it will run again for a few seconds and stop. ...
Check the door switch. It may be at fault here. Open the door and hold the switch by hand and start the dryer. The switch should have a firm resistance to it when you push it. If you should find this bad, here is the replacement switch. If the switch is ok, then the motor is bad. Here is the motor to order.
Keep me posted!
Nov 05, 2012 | Maytag MDE2600 Electric Dryer
My dryer ignites and after a few seconds the flame goes out
hold and assist coils
with model number i could get you the part numbers
Sep 29, 2009 | Maytag Dryers
Maytag mdet446ayw runs a few seconds and shuts off
maytag dryer mdet446ayw runs for around 30 seconds then shuts off
Apr 15, 2009 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Flashing "touchup" and dryer won't start
This unit should be on warranty, call back the seller for service.
Nov 08, 2007 | Maytag MED9600S Electric Dryer
Dryers Logo
205 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
