Either the back-up switch is bad or needs adjusting. It's pretty much when you put your car in reverse, it makes a switch which makes your back-up lights come on. Not sure about yours, but some are located under the gear shift console when the gear shift is moved it will then make the switch, and some are on the transmission. I would try adjusting the switch first, which the car will have to be in reverse to get the lights to come on. It can be a little dangerous, but make sure the car it secured and someone is helping you. Gear shift in reverse, with someone holding the brakes while the switch is adjusted. It hard to explain this process, but wish you luck in fixing it.
