Question about GE Spectra JBP78 Electric Kitchen Range
Electric burner one of the burners will not heat up or turn on.
  • Anonymous Apr 27, 2008
    gooktop burners wont heat up
    Scholar:
  • 178 Answers
Unplug the Range from the wall completely. Lift up the top to see under the burners and make sure they are contacting the connections for current. If they seem to be tight, plug it back in and try it. If that doesn't work, then you have an "Infinite Switch" malfunction. www.marcone.com is an excellent source for finding a do it yourself part to fix this. Please do not attempt to replace this switch with the range plugged in.
Posted on Mar 16, 2008
SOURCE:
All 4 rings get extremely hot immediately and don't cool down.
Appliance Science: The hot physics of induction cooktops ...
www.cnet.com > Appliances
CNETJan 12, 2015 - Induction cooktops don't heat up themselves: they create heat in the base of the cookware. ... the cookware, and so react quicker when you turn the dial up or down. ... US consumers don't like them because they grew up on gas rings. ...pans, they don't get hot when you put them on an induction cooktop.
4 Lessons I Learned From My Electric Stove - Life in the ...
www.thekitchn.com/why-im-grateful-fo...
Apartment Therapy's The KitchnFeb 24, 2015 - Electric stoves don't have a lot of redeeming qualities. ... "low" burners rather than wait for the front burner to sufficiently cool down. ... burner for all my cooking, as I did when I cooked on a gas stove. ..... I was used to looking at the size of the flame to gauge how hot it really was, I never looked at the dials.
Moving From Gas to an Electric Stove: What I've Learned So ...
How to Fix Problems With Burners on an Electric Stove ...homeguides.sfgate.com > Landlords & Tenants > Landlord ProblemsElectric stoves rely on electrical resistance to heat up the burners on the cooktop, which means they function much in the same way as electric heaters. ... When one of the burners stops working, you can usually trace the problem to the burner switch, theburner receptacle or the ...Electric Range Stove Repair: How To Repair Burner ...? 6:52https://www.youtube.com/watch?v=ndQU7RtqfRwJan 31, 2012 - Uploaded by applianceassistantHow to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... How To Test Stove ...Fixing Electric Stove Burners that Don't Heat Up Properly ...? 2:34https://www.youtube.com/watch?v=GfqaPcha__o
Dec 15, 2015 | Kitchen Ranges
2 hobs on my electric cooker are not working
? 2:34
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
? 6:52
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Burners and oven on Hotpoint free standing electric stove won't heat at all.
Find someone with a good electrical meter and have them test the sockets to see if there is any electricity to the burners.
Also, check each burner and check for continuity through the burner itself.
These elements can all burn out, I've see it happen.
Be blesssed.
Apr 17, 2013 | Kitchen Ranges
GE electric stove problems, our stove has 3 small burners and one big burner. When we use the big burner at medium heat it does fine then all of a sudden it starts glowing bright red and burns whatever is...
Replace the infinite heat control switch for that burner. (the burner switch that you turn with the knob to select the temp setting) If you list a full model number (usually behind the lower drawer panel on the frame of the range) I can look up the part number for you. It is not a very difficult repair.
Oct 11, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
Kenmore smoothtop model 911.9554590 duel size burners
the inner burner is broken so the whole thing needs to be replaced. check your owners manuel for warrenty times on the burner. otherwise just replace the burner and that will solve your problem..
Mar 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Burners on JP326 electric not heating
Sounds like breaker tripped so no 220 to unit. Reset breaker. The burner switch you first turned on probably blew out and needs replacing, so don't turn it on again. If all else works ok, then that is it. Unless you are handy you may want to call the repair man.
Nov 30, 2008 | GE 30 in. JP326 Electric Cooktop
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Electric Burners Turn On, Off, On, Off
the burners are halagen they are supposed to work that way but dont use them without a pan on them to reflect the heat back to the sensor to prolong their life
Dec 29, 2007 | Viking 31 in. DECU165 Electric Cooktop
2 burners work, 2 don't
ok, first check that the ranges are seated properly , clean the connectors , do a test , if it still doing the same problem , then you need to replace the modules of each range thats not working,in this case 2 modules.
Nov 15, 2007 | Kenmore 96213 Electric Kitchen Range
GE Spectra JBP78 Electric Kitchen Range Logo
59 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you a Kitchen Range Expert? Answer questions, earn points and help others
