Question about SanDisk Sansa e250 MP3 Player
Mp3 the blue light turns on on my sansa e250 but nothing else!1 what is wrong it wont be recognized either
    Problem Solver:
  • 12 Answers
Did You Try Pluging You Sansa Into Your Computer In Recovery Mode?
Posted on Mar 16, 2008
Just the blue ring, screen does not turn on
Blue ring faillure could be solved, trying to reset the e250.
How to reset:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Only if the reset action above did not help,
reload and update to the latest firmware.
Installing firmware will erase all data from the player !
  • Step 1: Switch to MSC mode.
How to switch to MSC mode:
1. Turn device OFF.
2. Slide the hold switch to the direction of the headphone jack so an orange color would show putting the device on Hold.
3. Press and hold the ( |<< ) button while connecting the device to the PC.
  • Step 2: Update to the latest firmware.
See next site for how to update the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
Follow the information in the link.
The easiest way would be using the automatic Sansa Firmware Updater. Directly to the download Sansa Firmware Updater .
Need more help ? Just post a comment.
Dec 19, 2009 | SanDisk Sansa e250 MP3 Player
Computer wont recognize Sansa Mp3
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Jul 19, 2009 | SanDisk Sansa e250 MP3 Player
Not working!!
this is a common. problem. http://anythingbutipod.com/forum/showthread.php?t=22253
that url should fix your problem.
Aug 02, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
Take the screws out of the back, take the battery out then put it back in again. This worked for me.
May 02, 2008 | SanDisk Sansa e250 MP3 Player
Sansa E250 Black screen lighted wheel, wont do nothing else.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Apr 09, 2008 | SanDisk Sansa e250 MP3 Player
Please help me
You have the locking button activated. Deactivate the button and it should turn on normal.
Feb 09, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player wont turn on and isn't detected by computer.
your battery could be dead. but when you plug it in does the blue ring light up
Jan 26, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 wont turn on
try holding the power button for20 seconds or the power and play button at the same time for20 seconds.
Dec 24, 2007 | SanDisk Sansa e250 MP3 Player
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
Aug 09, 2007 | SanDisk Sansa e250 MP3 Player
I need help with my sansa e250 mp3 player
Hi. Seems like your player may be encountering some corruption. Try this and see if it would help: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Let me know if this helped :)
Apr 21, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
55 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
