Question about Acer Aspire 5500 5570-2609 Laptop
MY LAPTOP IS ON AND NOT SHOWING ON THE SCREEN
My laptop monitor will not show while booting up the screen is black and when i attach a pc monitor to the back of the laptop the monitor on the pc will not show on it either. it was not dropped kicked or wet nothing happened to the laptop to cause it to once in a while come on or stay off.. also i took it to a computer person who says it may be a short HELP IT IS BARELY USED AND ONLY 2 YEARS OLD
    Champion:
  • 238 Answers
Hi, check the RAM, remove it and clean the contacts, if still no sucess then check it with another Working RAM, this will confirm if the RAM is BAD,,let me know..dont fall prey to the non-qualified engineers (i.e ur comp person)
Posted on Mar 16, 2008
SOURCE:
I tried to clean the dell vostro 1014 fan, after i assembled the fan and turned on the laptop it appear black screen with dim image on my laptop screen, When I plug in external monitor it shows boot s
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Mar 20, 2014 | Dell Vostro 1014 Laptop Computer
Toshiba laptop c660d-152 showing black screen asking for password
check whwther you have set password while booting if so enter bios pw
Dec 09, 2012 | Toshiba Satellite L455-S5009 laptop
My PC laptop monitor show yellow lines all over the monitor dnt know whats the real problem. I connect external camera its not working. It show troubleshooting and it says a mass storage controller is not...
Is your laptop booting on switching it on, ie, it is showing hard disk activity and shows initial boot screen. If yes, while switching on press F8 button very frequently. You will get a screen showing the options for booting. Choose a safe mode option and restore your computer to an earlier date. This may solve your problem. On the other hand just switching on the computer shows monitor with yellow and black stripes, you may have to take it to a service center.
Mar 22, 2011 | Computers & Internet
My compaq laptop powers up but the monitor stays black i tried to plug it in a monitor and nothing.
Unfortunately..your display may be shot...Is it a Compaq Presario? These laptops have a history of display problems...I have a Compaq Presario R3000 and the display is showing a reddish color in the left bottom corner of the screen and my brother had a similar problem with a Compaq laptop where the monitor stopped working....Unfortunately it would cost more to replace the monitor than to buy an Apple MacBook...
You can buy a cable and attach the laptop to a desktop monitor and it will work although you will lose the mobility of the laptop which is what makes a laptop so appealing.
If your laptop has a NVidia graphics card you can go to display in control panel and set it up to use Plug & Play Monitor but you may need to use safe mode or you wont be able to see anything because your screen doesn't work....You might get lucky and when you plug in the cable (just like you would to attach a PC tower to a monitor), it will work and you will be able to make the monitor the dominant screen.
Oct 29, 2010 | Computers & Internet
Laptop screen is not showing anything after power is on
if the power is on and the screen does not show up , try to hook an external monitor using the VGA cable. If the screen does show up, it means that the problem is in the laptop LCD monitor itself. Otherwise if the external monitor does not show up, that means your laptop does not boot anymore to the operating system. Try to turn off the power and remove the power cable and battery on the laptop. Then press and hold the power button for 8 secs. Then reinsert the battery and power cables on the laptop then turn on the laptop. If there is still no screen displayed then call Lenovo for repair of your laptop.
Oct 22, 2010 | Lenovo 3000 C200 Notebook
Acer aspire one ZG5....connected to another monitor pressed control key and F5. The other monitor starts to boot up windows, gets to a certain point and then shuts off connection from acer laptop, who's...
As by your description, your mainboard of the laptop is faulty as the unit fails to produce a good picture on both its own LCD and on a external LCD
May 25, 2010 | Acer Aspire 5100 Notebook
25mm wide white line down the screen near center
Please make clear that whether it is showing from when you boot your computer to loading desktop then LCD is damaged mean to say its hardware problem so take your notebook to HP service center.
other wise remove VGA drivers and re install. To Check Driver Problem... Attach One Extra Monitor to your laptop and ensure that line is not showing on that monitor.
Mar 21, 2010 | HP Compaq nc8000 Notebook
Dropped and screen went black.still turns on but the screen doesn't work
Attach and external monitor and boot the machine. If you don't have one, ask around your friends and family... someone has a monitor.
If you can see stuff on the monitor when it boots, but when you boot with no monotor the laptop screen is blank, then you most likely have a dead lcd panel on the notebook. It would need to be replaced.
If the external monitor also shows nothing during boot then you likely have larger problems.
Aug 09, 2009 | HP Pavilion dv9000z Notebook
Partial lcd display on laptop
Hi
Sometimes the resolution changes to an unusual setting when an external monitor is attached. make the LCD screen your main monitor and change the resolution to 1024x768 or 600x800 whichever is best.
Happy to help
CBZ
Apr 25, 2009 | Toshiba Tecra A4-S313 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
61 people viewed this question
Ekse
Alun Cox
