Motherboards
Problem for Motherboards
Generic problem for all Motherboards
Motherboard
By Tankaman on Mar 16, 2008
well i dont know fo sure but i think i crashed i dont get a display when i hook my 9600gt up to the monitor and and when i take the ram i out it still beeps and stuff but i dont know wat else to do its a pent 4 i think the processor loose or something cause the other day i had the computer blow out or wat ever and the guy had to un screw my processor to blow it out i think he F up proceesor
but is there a way to know if somethings wrong with the comp dealing with
1. processor
2. ram
3. my 9600gt cause i was getting this strange error before it killed or watever like intel boot system not found or something
4.bios ,cmos but cant check those two cant loggin to my comp
5 anything else plz i need help
Comments:
Mar 16, 2008
- D915GRO/D915PRO/D915GVR0 i think thats it
the beeps only happen when i take the ram out and its its kinda of a 1.................2.................. 3................. type beep i guess u can say it long beeps
Solution #1
posted on Mar 16, 2008
Somewhat Helpful)
map9966
Rank: Guru  Computer Components  Expert
Rating: 89%, 1956 votes
Ok Tankaman lets start from the top.
(I can not see the pictures you posted).
One does not unscrew a processor. From your description,
(the guy) most likely unscrewed the processor's fan & blew it off.
The error messages you were getting & I have to guess at this.
Your PC could not find the boot device. Check your cmos.
So here's what I want you to do.
1. I need you to find the Name & Model number of the machine.
It will be marked on the case & within your manual. It’s better if you find it on the case. Check the front of the PC; check the back & both sides of the case.
2. I need to know about the beeps.
These beeps you are hearing. I need a better description.
(Ex: 1 long & 2 short beeps or like, 3 short beeps with a pause of 2 seconds than 3 short beeps again, & repeating.)
This will help a lot!
3. I'll need to know the operating system your running.
Like Windows XP Home Edition, Windows Media Edition?
While I'm waiting for you to post the needed information I'd like you to do this. (but only if you know what you’re doing.)
1. Unplug the power cord from the back of the PC.
2. Standing in front of the PC & looking at the front of the case, remove the left side panel from the PC. You may need to remove a couple screws from the back side to get the side panel off.
3. Find the section in your manual that describes installing your memory. Remove your memory. (if there is more than 1 memory module, remove only one at a time.) Than reseat the memory as shown in the manual. Do not force the memory it only goes in one way. (Check your manual). Be firm but not brutal.
Try not to touch the copper colored metal with your fingers.
4. Do the same with your video card. Remove & than reseat.
5. While the PC case is opened look at the board. You should be able to see the name of the board. It will be marked in white lettering. (Ex: Asus P4GE-MX v.1.0)
6. Re-connect the side panel to the case.
7. Plug the power cord back into the power supply.
8. Turn on the PC & listen for closely for beeps.
Post all this information back here Tankaman.
Good luck.
Waiting........
Comments:
Mar 16, 2008
- Tankaman.
The only reason I wanted you to take the memory out was so you could put it back in.
That was to make sure it was seated in their slots correctly.
You do not power on the PC with the memory/Ram removed.
The computer will not run with the ram removed.
You will get beeps that repeat warning you that your memory is missing or bad.
A working PC will beep only once.
That 1 beep is called; P.O.S.T. (Power On Self Test.)
I'll post a link that you can click on.
The link will show what beep codes mean for the Award bios.
(This is to help you understand beep codes).
http://www.bioscentral.com/beepcodes/awardbeep.htm
So put your ram back into their slots & turn on your PC.
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS... (More)
Answer
compaq presario mother board, what should I replace it with
Answer
i am using dg43nb board 1g ram and 2.8 core 2 duo but when i start my computer it takes so long as... (More)
Answer
where to attach reset key wire on motherboard? its ax4bs.. pls help me my computer is nt working... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
in , CA
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
