The laptop comes on and the monitor will not show it was not dropped damaged or wet it comes on periodiacally it seems to be a short somewhere because when you hook up a pc monitor to it the screen will not show on it either
  • vipgyrl216 Mar 30, 2008
    I took the computer to an qualified computer technician and they had no idea either which they sent me to this site because it would not take a regular monitor either. they thought it was a short of some kind because the monitor comes on and off when it fills like it.. sometime booting all the way and other times not booting all the way or not coming on at all. tried it two days ago again and it came on and stalled and when turned off it is difficult to just turn off need to hold the power button longer just to turn off sometimes. the tech thinks I should just get another laptop? I want to try the first solution to take the ram out and clean it and the second thing i would try is an inverter if neither works I will never buy another ACER again
    Problem Solver:
  • 12 Answers
What is the make and model of the laptop? It could be a bad inverter, and the easiest way to tell is to plug a regular monitor into it (if it has the appopriate port). If the regular monitor works fine, then it's probably a bad inverter and you should send it to be serviced.
Posted on Mar 16, 2008
Car dieing periodiacally when all lights dim
check the output of the alternator and check the alternator belt may be loose.
Dec 23, 2013 | Pontiac Grand Am Cars & Trucks
Where is the samsung laptop service centre in DC, USA
It would certainly seem so. Has it been damaged? Dropped, Jarred, bumped? If your not comfortable with opening the laptop, take it to a Qualified Computer tech. There are connections in the rear of the monitor, a ribbon cable, and at the bottom of the monitor, behind the bezel.
Dec 28, 2012 | Samsung Computers & Internet
The screen will not come on
Screen is probably damaged. Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
Mar 28, 2012 | Twinhead Durabook N15RI-2 Notebook PC
Horizontal lines in my laptop screen & its is increasing while using. it is also visible while using booting. it first happened shortly after washing with a liquid.
The display board in your monitor is posibly has liquid damage if it got wet. you will need to replace the monitor is this is the case.
Aug 11, 2010 | ASUS VW222U Monitor
Monitor problem.
um.. im just gona say this it seems obvious but on mine one of the leads connecting the sub to the rest of the cabinet fell off and all i had to do was reconnect it and it was fine.
Aug 11, 2009 | Yamaha NS-A636 Speaker
Screen won't display
It's quite possible that the mother board (your main circuit board) and/or display adapter was damaged. Your only recourse now, most likely, is to contact HP. Good luck!
Apr 18, 2009 | HP Compaq Presario R4000 Notebook
No video, drives work, everything seems OK, but will not drive external monitor either. Several times, when dropped 6" to table top, some video showed briefly, so I suspect a short or more likely open...
Something like this would be very difficult to diagnose. It sounds like an issue with the graphics controller, which is integrated onto the motherboard. My advice would be to see if you can replace the motherboard or find one on eBay that is broken and use it for the motherboard.
Apr 17, 2009 | HP Pavilion zt3010US PC Notebook
Laptop Screen
Sounds like the drop damaged the screen. To check this, connect it to an external monitor. If everything works properly, then the screen is damaged and will need replaced. If it doesn't work properly, then a motherboard component has been damaged, and you will most likely want to take it in to have a professional diagnostics done.
Aug 07, 2008 | Computers & Internet
Moniter
There is a short somewhere else. You have to try the other boards and use the process if elimination to service this.
This is why I tell people not to go out and buy a board on a guess. It is possible to have a short somewhere else that damaged the supply, and you may now have a newly damaged supply with still having the original failure that must be first found!
The factory service people have the necessary jiggs and diagnostics tools to figure out what the problem is.
Jerry G.
May 16, 2008 | Gateway FPD2275W LCD Monitor
MY LAPTOP IS ON AND NOT SHOWING ON THE SCREEN
hi, check the RAM, remove it and clean the contacts, if still no sucess then check it with another Working RAM, this will confirm if the RAM is BAD,,let me know..dont fall prey to the non-qualified engineers (i.e ur comp person)
Mar 16, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
David Payne
David Payne
