42 inch magnavox #42mf230a/37
Suddenly i have a black line about six inches wide (black) running almost straight down the center of the screen. what could it be?
  • davidbledsoe Jan 05, 2009
    I have a similar problem and have attached a picture to illustrate. Mykids were playing with their Wii and in the middle of the game thepicture disappeared and flashed a white screen then a black screen andthen immediately went to this white/black/white vertical stripe downthe center.
    Would this be indicative of a bad driver IC as well?
    Sergeant:
  • 261 Answers
One of the driver IC'S has gone bad. Need to replace just the driver IC or the board that the IC is on and that should solve your problem. If that doesn't do it, then the BAD NEWS IS THAT THE PANEL IS BAD. Replacement is you only option then. Good luck. GURU JAY.
Posted on Mar 16, 2008
My screen turns completely blank for about 5-20 seconds randomly while TV is on.  If I tap screen it comes back on.  Model is: 42 inch magnavox #42mf230a/37.  What is wrong with it? What do I do?
Posted on Nov 24, 2008
Vertical Line on Phillips 42PF7320A/37
Hold down the cursor button towards the green line, it's really that easy...
Mar 07, 2010 | Philips 42PF7220A 42 in. Plasma Television
Magnavox 42MF231D/37 screen went white then black
Alot of times i have noticed that when i have worked on these, it has been the Backlight Inverter. 32 inch televisions had same problem as the 42 inch
Oct 18, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
I have a magnavox 42mf230a/37 with black screen
more that likely your set got a serge and bleew a couple of capacitors in the power supply esay to find they will have dome on the tops from venting
Sep 17, 2009 | Televison & Video
Horizontal lines on screen
well if they run all the way up and are on every input through then menu the panel is NG, some panels are around $500 now.
Jul 26, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Magnavox 42MF7000/17 Green Stripes Pixel down section of display
Possible Defect in programing. Call Manufacturer for possible support in Updating Firmware.
Jan 18, 2009 | Philips Magnavox 42MF521D/37 Television
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black band running from top to bottom of screen
this will need to go into the shop to get one of the video processing boards replaced that controls that part of the screen , this will happen when it gets to hot inside the set ,( thermal break down)
electech
Oct 31, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
I have a plasma tv need help
Sounds like panel is bad or driver ic is bad on the board directly below the black line. Good luck on the repair. Any questions, we can do a chat and go from there. GURU JAY
Mar 14, 2008 | Televison & Video
Televison & Video Logo
1,097 people viewed this question
Top Televison & Video Experts
