Question about Brother MFC 420CN All-In-One InkJet Printer
Changed all 3 colors and black---Red not printing
When printing, no red is coming out. Prints brown??? Help
email to : riversonjr@comcast.net
  • bobiv Mar 17, 2008
    Thank you Guru,
    It worked, all clean and all 4 clear on test print.
    riversonrjr@comcast.net
  • la_jolla_ace Apr 11, 2008
    same problem except mine is barely printing magenta. On the test print only four tiny red dots appear. I installed new print cartridges but that did little more than shrink my wallet. I tried the suggested solution (menu, start bk - copy, up, up, up, up, 7,6,4 start bk, 7,6,3, start bk, 9, 9, test print) and still 4 red dots. I chose no, yes, no for quality ok, black ok, and color ok respectively and chose yes for start cleaning. after cleaning I printed another test page same thing, except the dots are getting darker as I clean.So i went back in to maint. mode and tried 7,6,2 and then 7,6,5 (I don't know what they do i'm just that kind of guy) after they completed I 9,9'd out and tried to print another test page. still 4 dots, still getting darker, so I chose no, yes, no, yes for quality, black, color, clean - respectively. After cleaning I tried printed another test page but got a paper feed error so I inserted a piece of paper in the tray and pressed start again. The test page printed and low & behold 4 red dots. I went back into maint. mode and tried 7,6,1 (again not knowing what these codes mean just being that kind of guy )and pressed bk start when it said "something_p all" (forgetting what something was) after another cleaning cycle i tried 7,6,0 and it went into some crazy clean cycle that was non stop until i got machine error 8A, so I 9,9'd out of that and went back into maint mode and tried 7,6,7 - the message said c-p-cart all and sounded like it was doing something so I waited and waited and waitd a long time - and when it was done and again said MAINTENANCE I tried 7,6,6, (realizing i skipped it earlier. 7,6,6 gave me a message of eINIT_P ALL. Determined to go through all the 76's I tried 7,6,8 and 7,6,9 which read DRYPRF_P ALL and INK_NUKI ALL respectively. After I completed all the 76's I was feeling quite pleased with myself so I went ahead and tried 7,6,0 again because I liked the way it sounds and because I wanted to see If I would get another error 8A message. I did so I 99'd out and tried printing another test page. THIS TIME I GOT 6 RED DOTS!! so again I chose no, yes, no for quality ok, black ok, and color ok respectively and chose yes for start cleaning. after cleaning I printed another test page ...6 dots. I'm not sure if I going to move up to the 77's or down to the 75's but if you have any suggestions I would appreciate them.
  • 832 Answers
Print is brown: mingles yellow with bk and cyan and red.
Did you use generic ink? You have to use a set of original brother ink carts: dinsert the original carts. press menu then start b/w copy then fourtimes arrow-up. when machine is in maintenance mode press 7 then 6 then 4 then start b/w copy. machine will initiate the carts and do some power cleaning. whnen finished press 7 then 6 then 3 then start b/w copy. machine does a power purge. leave maintenance by pressing 9 then 9. Do run a test print. If you cant see any mag. do the power purge two days later. If your not lucky then (you cant see ANY mag squares on test print) the head is defective and needs replacemnt.
Posted on Mar 16, 2008
No red
the color red is a mix of two color. so run the cleaning tool on the printer
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
Dec 12, 2009 | HP PSC 2175 All-In-One InkJet Printer
Problem with color
Hello Melinda
I would suggest cleaning the printer head.
The print test has the same problem?
May 12, 2008 | HP Photosmart 8250 InkJet Printer
Red color not printing right
2600N Optics file on the HP forum page. Or email me at mcchord@comcast.net and I will send you the file on red color fading. The file says that if you are getting light red fading or orange to use the File I mentioned to resolve.
Jul 01, 2009 | HP Color LaserJet 2600n Printer
Changed all 4 cartridges, yellow, red, grey not printing. Only blue & black print
Sounds like most of the color lines (the "cables" between print head and cartridges) either have clogged ink in them, or air bubbles. Try the cleaning process found by pressing Ink Management and then Menu/Set twice. After the test print sheet is printed, answer the question(s) in the display and print up to five test prints by answering the questions.
It should solve the problem, but if it doesn't, you should perform a heavier duty purge found in the service mode.
Jun 02, 2009 | Brother MFC 420CN All-In-One InkJet...
Unable to print on printer Dell 926 -test page prints ok
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
May 23, 2009 | Dell 926 All-In-One InkJet Printer
Colors are all wrong!
check colors make sure their in right then keep printing till it cleans up
Mar 29, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Prints suddenly red & cleaning doesn't help
The Color printer catridge ink might be low . You nned to replace.
Dec 15, 2008 | Canon i860 InkJet Photo Printer
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Installation disks
Here is the link for the driver:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:435:0:0
Just select which operating system you have and then you should be able to download and install.
Nov 08, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Hp 3745 prints only the red color
This is Romeet, id like to try and help. Assuming you have windows XP installed,
go to "Start", select " Printers and Faxes"
go to your printer ( HP deskjet 3745 ) and right click it and select properties.
Click on " Print Test Page ", tell me what color does the Printout come in.
B.Regds
Romeet
Oct 31, 2007 | HP DeskJet 1280 InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
539 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
