Question about Motorola Mobility W375 Cellular Phone
Motorola w375 my motorola w375 camera is really dusty inside is there a way for me to clean it? all my pictures look really bad you can barley see any thing.
  • churro Apr 03, 2008
    its not dusty on the outside its dusty on the inside
Use a cotton bud, damp, if it very dirty. Then, use a food cocktail stick to go round the circumference of the camera a couple of times. Do this as many times as needed, it will help with the outside of the lens. Hope this helps, even if just a little bit.
Posted on Apr 03, 2008
SOURCE:
I've got some visible(I see it on the pictures and on the digital display) dust (tiny hairs etc) on my lens (actually inside) so it seems I can't get rid of it without taking my cam apart. The dust is then...
If this is a fixed lens camera (you didn't give a model) I'd suggest strongly for you not to attempt to take it apart. Hopefully what you are experiencing is dirt on the outside of the lens. If so turn on the camera huff (breath) on the lens to create a slight amount of moisture and then use a lens cleaning tissue to gently clean the lens.
If as you say this dirt is on the inside then I would suggest getting it cleaned by a camera repair facility. Problem there is a lot of these point and shoot cameras cost more to clean and fix then it does to just go get another one.
Next thing if the inside is dirty they you must have a lot of lint in your pockets or you have been using this camera in a dusty environment. For carrying it would be best in an actual camera case rather then an open pocket and for dusty condition I've used shallow water camera bags and I've also used ZipLock bags while photographing a waterfall.
Apr 12, 2011 | Panasonic Cameras
I lost my drivers. it s not getting connected to pc
HOWTO_Connect How to connect Motorola W375 to a Windows computer Introduction¶ This document describes how to connect your Motorola W375 to your computer in order to use it as a modem, or to administer it with Motorola W375 Manager software.
Connecting¶ To connect your motorola W375, follow the next steps:
  • Download and uncompress Motorola W375 Driver from this site.
  • Connect your W375 to your computer with its lid closed.
(You can also connect the device with its lid open, and choose "not" when it asks for permission to connect as an storage device)
  • When Windows asks you for a driver, select Motorola W375 driver folder.
This way, the next time you connect your mobile phone closed, your computer will recognize it as a new communications port and you are ready to use it with Motorola W375 Manager. If you open this "COM" port with a terminal emulation software (i.e Windows Hiperterminal) and type "AT", the mobile phone will respond you with an "OK" string.
Using it with Motorola W375 Manager¶ To use your mobile with Motorola W375 Manager, simply connect your mobile phone closed and then, start Motorola W375 Manager software.
Using it as a modem¶ To use your mobile phone as a modem, install "Standard 19200 Modem" driver and select the communications port associated to your motorola W375.
About Motorola W375 driver¶ Motorola W375 driver is basically the same driver known as Motorola USB Charging Driver. You can download Motorola USB Charging driver from motorola US support web site for Motorola W375. If you try to use Motorola USB Charging driver directly with your Motorola W375, device type will not be recognized, but if you change device ID from "USB\VID_2811&PID_0702" to "USB\VID_22b8&PID_4061", this usb charging driver will become completely compatible with wour Motorola W375 mobile phone. The driver you can download from this site, is exactly a Motorola USB Charging driver with the mentioned modification.
Dec 07, 2010 | Motorola Mobility W375 Cellular Phone
Does this phone have blue tooth and how do you switch it on
The Motorola W375 is a basic quad-band GSM flip phone that sports a built in FM radio and VGA camera. Other key features include a 2.5mm headset jack, speaker phone and external indicator lights.There are Bluetooth adapters that plug into your Motorola W375 cell phone's 2.5 mm jack and convert your non-Bluetooth phone into a Bluetooth wireless device.
Oct 25, 2009 | Motorola Mobility W375 Cellular Phone
The inside of my powershot a590 viewfinder is really dusty and i need to know how to clean it
microfiber cloth u can find these at costco use them for any optical cleaning TV's, sunglasses and cameras
Sep 02, 2009 | Canon PowerShot A590 IS Digital Camera
How to download pictures from motorola W375 to PC ?
Hi!
Use the program motorola phone tool for that, you can download it from here:
http://direct.motorola.com/hellomoto/nss/productresource.asp?PhoneModel=mpt
YOu can use it to download or upload to your phone
Good luck
Nic
Mar 23, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Mot.#W375 down. pictures to pc
Easiest possible way is with a microsd card. Save all of the things u want onto ur sd card and then put it into ur new phone. Its quite simple, but if you have any further problems, [email protected] is my e-mail address and I will be more than happy to help you.
Mar 22, 2009 | Motorola Mobility W375 Cellular Phone
Motorola W375 not getting pictures from LG Shine
the lg shine does not really have that much internal memory so what you can do is get an external memory card for your phone and bluetooth it to your phone if not then what you can do is send the picture to your email (send it like a multimedia message to you email) and open it in a photo editing program anything that can change the size of the picture to 320*240 and then email that to your phone and it should work. and tell her to change her settings in her camera to the lowest setting and then take the picture and send it. if you need any futher help let me know
Jan 09, 2009 | Motorola Mobility W375 Cellular Phone
Internet downloads
Hello there. i am sorry to say you cant. the motorola w375 does not allow you to put anything more than pictures and songs on your mobile through usb. however you can download things from the internet off the phone.
Aug 02, 2008 | Motorola Mobility W375 Cellular Phone
Transfer photos
Most motorola phones are plug and play. Get a USB cable and you should just be able to plug it into your laptop and view it under my computer as a removeable drive. Then you can drag and drop files between them.
Or you can send a picture message to your email address, standard rates would apply for this.
Or you can download motorola phone tools software from motorola its about $30.00. This is synchronization software for file transfers and address book and calander synchronization.
Jan 27, 2008 | Motorola Mobility W375 Cellular Phone
Unable to download photos from motorola w375
you will need motorola phone tools in order to transfer photos and music to your phone. and for information, your phone can only have 1.5mb memory therefore it wont hold much pictures
Dec 27, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility W375 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
