Question about Kyocera Mita FS-1030D Laser Printer
Kyorcera FS1030D - error light sequence what does it mean
After printing fine for ages the printer made a sound like paper was jamming and then has stopped working. We have removed all paper and shaken and removed the cartridge but to no avail also checked that all jobs have been cancelled and all doors etc on the printer closed.
The seqence of blinking lights is:
data indicator then the attention/data/ready indicators all together.
I can't find anything that tells me what this might mean. Hope you can help
  • 24 Answers
If you mean that the sequence is: 2nd led and then 1st+2nd+3rd
the problem is in fuser unit. You have to call a technician to check the lamp, the thermistor and the thermostat inside the fuser unit
Posted on Mar 19, 2008
What would cause paper jams in a hp 4100 printer
Where is it jamming. Printer this age could have fuser issues, worn rollers that are not picking up properly. Is the jammed paper crinkled up or does the printer stop before damaging the paper? If paper is not damaged, the cause is usually in the paper pickup slipping and causing the printer to think that the paper is either too long or too short. Clean all the rollers in the paper tray cavity with a damp cloth.
Sep 05, 2014 | HP LaserJet 4100 Printer
Dell 1720 printer single-sheet feed stopped working
Pull out the paper that is jammed and continue.
Nov 29, 2012 | Office Equipment & Supplies
In trying to repair my Lexus x6570 the teech over the phone hhad my pull the paper out of the rollers & then then printer stopped working. Everything was woorking fine until this incident. Are you...
I'm not sure if I understand you correctly but it sounds like you had a paper jam problem and now your printer is not functioning properly. Here are some tips:
  • Make sure to remove the paper jam completely.
  • Avoid leaving torn paper in the printer, this would cause future paper jams.
  • Unload the sheets of paper from the feeder. Open the printer cover and remove the cartridges. Close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges and then close the printer cover. Load some paper. Try to print again.
Jun 26, 2011 | Lexmark X6570 InkJet Printer
Will not feed paper
Unplug the printer and wait half an hour. You want the internals of the printer to cool down, otherwise they might burn you.
Open the top of the printer, and remove the toner cartridge, there will be visual instructions printed on the top of the cartridge on how to remove it. Take care to place this on paper towels, as toner can be shaken loose and will stain anything it lands on.
You should be able to see a paper jam under where the toner cartridge, reach in and remove this jam.
After you've removed the jam, replace the toner cartridge and try printing again.
Mar 06, 2011 | Brother HL 2140 Laser Printer
EPSON DX5000 will not feed paper. It goes in about 1 inch then stops. No jam warning until it appears to finish printing. When I renmove the paper there appears to be a small dent in the leading edge of...
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | Epson Stylus DX5050 All-In-One InkJet...
False "paper jam" signal prevents printing: My HP 2210 had been working fine. Suddenly, when I try to print, the paper starts to feed for a few inches and then stops. I get a "clear paper jam" error...
it's probably due to what i would call the print head blocker ( on your left handside of your printer head) that is broken . check it out! it also responsable to control how far goes the sheet before start printing.
Jan 14, 2010 | HP PSC 2210 All-In-One InkJet Printer
Epson C88+ printer paper issue
There may be a small piece of paper still stuck in the mechanisms.
Aug 19, 2009 | Office Equipment & Supplies
Paper Jam/Stall - no paper jam
Well what you need to do is do a rest on the printer.That should solve the problem.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Jun 18, 2009 | HP Photosmart C4580 All-in-One InkJet...
1 get 3 fuzzy lines on page
If you're getting frequent paper jams, it's usually caused by the feeder motor assembly failing. When the paper is pulled through the printer, if the assembly is failing, it causes the paper to jam and can effect how things are printed. (Sometimes it will go to fast and things will get blurred, sometimes it'll go to slow and text overlaps)
If that sounds like the problem, it's cheaper to replace the printer (can be bought for $50) the it is to repair it ($25 for the motor, $45 for labor to install the motor)
Aug 28, 2008 | Samsung ML 2010 Laser Printer
Paper jam
I have had this problem, and have became very furiated.
Clear the Jam by removing and paper you see in from the rear access door.
If you are printing something from a PDF website....... make sure to have it still in the printer schedule.... It will still say printer jam..... but have it there regardless if its something you dont want to have to retype into the pdf form........ After that simply restart your computer. It should resume printer as soon as your computer boots up.....
Worked for me..... Hope this helps everyone else whos probably cursing your printer at the moment!!!!
Mar 22, 2008 | HP Deskjet F335 All-In-One InkJet Printer
Kyocera Mita FS-1030D Laser Printer Logo
993 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
