Question about Canon PowerShot A570 IS Digital Camera
Why does the LCD act crazy?
I am not sure even how to turn on or off the LCD screen. I use my camera in "auto" becuase it is most simple for me. Like today .. my daughter was taking a few pic's of her and some friends .. well it was going good I.E. Snap the shot, pic showed on LCD for 2 seconds then camera went black while processing it, then popped back on agin .. this went on for a good 5 min ... then a pic was taken and the LCD went black and didn't come back until I pressed the disply button 3 times. I have never had this trouble with our previous cameras .. hmmm these manuals are confusing to understand as well. I appreciate ur answer tho .... I don't want to have to send it away!!
Christy
Select reset all function in menu and press ok. Your camera will set on default factory setting.
Posted on Jun 07, 2008
My nikon coolpix s9100 seems to be blocked. the play/preview button will work to turn on the camera but not to actual preview anything. the buttons are working crazy
When your camera acts crazy, remove the battery , and after a few moments reinsert it. If the problem returns, there could be a more serious problem, that I can't solve, unless you have more information, about whet the camera does. Like giving a message on the screen, or some beeps, anything.
Feb 01, 2014 | Nikon COOLPIX Cameras
The LCD on my A590is camera doesn't work. When I
if the lcd is flexible then mostly the problem is with lcd connector.if you have a v cable then connect it to tv and see if picture is coming, if it comes then connector is faulty for sure
May 28, 2010 | Canon PowerShot A590 IS Digital Camera
My lcd screen will not show the picture. The
First try pressing the DISP or DISPLAY button to make sure that you didn't accidentally turn off the LCD. But if that's not the case...
Try taking and downloading a picture taken while the screen is blank. Is the picture also blank? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Read the users comments there also for more tips.
Jan 31, 2010 | Canon PowerShot SD1000 Digital Camera
Kodak z760 lcd screen will not work in the auto
It could have something to do with the batteries/ battery compartment: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 14, 2010 | Kodak EasyShare Z760 Digital Camera
LCD screen is black-cannot take photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 16, 2009 | Kodak EasyShare CX7330 Digital Camera
S2 IS black screen of death
Yes there are a lot affected. But if you want to try fixing it yourself (without even opening the camera or touching screwdriver), consider trying the following.
Jul 10, 2009 | Canon PowerShot S2 IS Digital Camera
Flash settings Sony DSC-H7
I had the same problem with my DSC-H9. The flash setting is set off when in BURST record mode. Go into MENU, scroll down to REC Mode, change it back to NORMAL.
Now go shoot someone or something... with your camera of course!!
Mar 12, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
ACER AL1716 acting up BAD!
Be more specific. I guess your monitor has inbuilt speakers which are making noise. If yes do come back for a solution.
Sep 30, 2007 | Acer AL1716 17" LCD Monitor
Camera won't turn on
not sure if you have the same problem..but i have the same camera and when i turned it on the screen was all white..it still worked and took pictures but i could only see them on the computer.. i had my friends dad open it up and he found a foam like piece that fell from somewhere and was causing a wire to short out in the LCD screen.
Feb 16, 2007 | Samsung Digimax A503 Digital Camera
Canon PowerShot A570 IS Digital Camera Logo
94 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
