Question about Radio Communications
Galaxy DX959 Hi, Can anyone tell me the maximum watts you can get out of a Galaxy DX959 if it is tuned & peaked. Thanks Jon
Mine puts out only 13 watts am
Posted on Nov 10, 2008
Hi, thanks for the info chiaflub67. I didnt think I could get much out of it. I bought it right for a spare. I usually run a galaxy 88 which does a great job. Thanks again for the info!!!
Tumbleweed01
Posted on Mar 16, 2008
  • 37 Answers
The 959 is not one radio you can get alot of power out of possibly 25 watts if it is tuned properly
SOURCE:
Is it good for a Galaxy 29HD peaked & tuned to dead key 3 watts and swing almost all the way to the right? I run a 4ft.Firestick antenna.
Stock radios dead key 1-2 watts and swing 4 watts max per FCC regulations. The swing is when you speak or whistle into the microphone. All the way to the right does not tell me watts or type of meter, so I cannot say. Typically to the right does mean more power out. Looks very good at 3 watts. For most people I suggest a longer antenna. Length = range, especially for CB's.
Oct 02, 2017 | Galaxy Radio Communications
Someone peaked the radio, i want it back to 4 watt, how do i do it
you will need an external watt meter and an alignment diagram. Go to www.cbtricks.com , look up Galaxy, dx939 and click on the radio alignment and it will tell you which variables to turn to get it back to 4 watts.
Feb 01, 2013 | Galaxy Radios DX 939
How do i peak and tune my galaxy dx 55v
Rather than turning it up ,buy yourself a small 200 watt linier and connect it to your radio.That way if you don't like the way it sounds just take off the box and sell it .Your radio remains the same.
Oct 22, 2012 | Galaxy Radios DX-55V Base CB Radio
Just purchased a new galaxy dx959. Coax and k40 10k watt antenna. Installed it in my peterbilt 379. I have a lot of background noise. I tried unhooking the coax from back of radio and the noise goes...
You probably have the 959 that has a MOSFET final. It is not recommended that you try to get more power/mod by just turning pots. This can shorten the life of the MOSFET drastically. I normally set the power output to 7 watts and the mod to 100%. This give around 30 watts peak on AM and around 25-30 watts sideband. You need proper test equipment to align the radio.
As far as background noise, this type of radio does have more that others. Make sure the Noise blanker and ANL are turned on. If you are getting noise from equipment in the vehicle, you should take your truck to a good CB shop. They can find out what is causing the noise and fix it.
....Don at NTCB, Inc.
Jun 08, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
How many watts can you tune the dx-33hml up too
Any where between 15 and 25 watts for a single final radio with a standard peak and tune.
Sep 05, 2010 | Galaxy Radios DX-33HML 40-Channels Base CB...
Just want know how to peak the power back up on my 29 ltd classic. its only putting out 2 watts on ch. 20 I suspect someone had a linnear on it prior.
Just tune L10,L9,L8 for maximum.
How electronically able are you?
I can tell you how to do what most call the super modulation mod, it isn't too hard and isn't very expensive. (Unless you take it to a CB shop!)
Oct 07, 2009 | Cobra 29 LTD CB Radio
Galaxy DX959
it can not be tuned to go high or low you need to add switches for that and then realign the radio.
Mar 08, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Peak tune
take it to a cb radio repair shop ,tell them to peak and tune to its max
Apr 06, 2008 | Uniden Bearcat Pro PC68Elite 40-Channels...
Radio Communications Logo
350 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
