Question about Lands Phones
Imate Jamin - daylight saving error
My imate thinks that daylight saving has started in New Zealand and automatically changed the time back one hour. (government changed our daylight saving hours last year, so now daylight saving won't finish for another two weeks).
Anyhow, I manually corrected the time on the phone, but it has cleverly altered all my forward appointments in outlook so that they are one hour earlier.
I hoped that synchronising with my computer might sort this issue but that didn't work.
Will I have to manually change EVERY appointment or is there an easy solution?
  • 2 more comments
  • Anonymous Mar 16, 2008
    Same problem!
  • bridget111 Mar 17, 2008
    worked a treat, thanks.
  • Anonymous Mar 12, 2014
    convert to daylight savings time
  • Anonymous Mar 18, 2014
    I tried changing manually but did not stay it used to do it auto
Seems to have fixed my jamin as well.
Posted on Oct 06, 2008
Yes - i had the same problem.
Goto microsofts download area, and download the patch for windows mobile (assuming you are using v5.0 or v6.0).
The patch is:
I've just installed it as per their instructions and it worked perfectly
Posted on Mar 16, 2008
Imate 9502 daylight saving time reset. How can I stop my imate 9502 phone from reverting back to Australian EST although DST ended on 3 Oct?
Go to 'Start > Settings > System tab > Clock & Alarms > Time tab', and make sure the 'Sync to current time zone' checkbox is unchecked. Press 'OK' a couple of time to leave the settings pages.
This way, you'll have to manually set your correct time when a DST time changes.
Hope it works for you.
Anyway, please, let me know I can assist you any further.
Nov 04, 2011 | i-mate Ultimate 9502 Cell Phone
I need etrust antivirus software free,, supported imate jamin pm300
use kaspersky antivirus
go to from your mobile and download the software
Feb 05, 2011 | imate JAMin Smartphone
Gprs setting on imate jamin.
Download imate-configurator from the imate website.
Go to:
  1. Enter your country name
  2. Select "Support"
  3. Select "Device Support"
  4. Select "Your Phone"
  5. Select "Patches"
  6. Download i-mate configurator
install the cab file in your device, the settings will automatically be done.
You may then connect to the internet.
Please rate if this helps you...
Jul 22, 2009 | i-mate PDAL Pocket PC
How to reset imate jamin password?
You can try with hard reset, i am not sure if it will work : keep pressed volume - , on/off button and reset button( from the bottom side of the device) for a few seconds
Jul 18, 2009 | i-mate JAM Pocket PC
Imate jamin mobile
hi thanks for using fixya!!
You may install programs to your Imate by using ActiveSync, just install first your activesync to you computer and then after the successull installation of the Activesync, connect your Imate to your pc using usb cable, then click activesync from your pc then it will automatically prompt you for your preferred activesync settings.
Then on installing programs, if you have the program in you pc just click the program to run and then it will automatically install it to your pc and PDA, but if you want it to install directly to your PDA, you should copy the program using activesync to your PDA, just save the prorgam file to the internal memory or to the sd memory and then from your PDA you may install it smooth and easy.
If you do not the activesync you may download Here
If you need further, let me know!
Please rate my simple solution positively! thanks!
Jan 31, 2009 | i-mate JAMin Smartphone
Imate jamin not turning on and not charging
I had the same problem with my Jamin so sent if off to the technician who informed me the Jarmin's internal circuitry prevents the phone being charged when the battery is under a certain voltage so when you use a plug in charger because the battery has very low power it does not trip a circuit in the Jamin to start the charging process. The only solution to to take the battery out of the unit and charge it with a stand-a-lone charger. Hope this makes sense.
Sep 13, 2008 | i-mate JAM Pocket PC
Imate jamin bluetooth car connection
youre dewice has no driver for the hands free
download some and instal then try
Jul 05, 2008 | i-mate JAMin Smartphone
Imate jamin upgrade
yes, of course you can.
i've upgraded many Jamins to the WM6 and even WM6.1
try this link:
if you need any further info or help just sent me a msg.
Jun 08, 2008 | i-mate JAMin Smartphone
Lost of drivers of imate jamin
i lost my pc suite for my mate,how can  get it
Apr 14, 2008 | i-mate JAM Pocket PC
Imate Jamin Sync problem
Hi Alwyn, i had the same problem & had to reinstall everything & then it worked. However it does revert back to giving the same error code from time to time. I think its coz i bought my imate jamin from a firm in sydney over the internet. When i got it, it had no mms settings on it [i later discivered it was an 'import' so i had to delete all its software & reinstall everything from software off the net]. I've been through hundreds of dollars trying to solve this problem [i originally thought it was my desktop soo i bought a laptop to synch with & it did the same]. You just need to persist in re-setting up the bluetooth when it does it but remember to cancel all previous bluetooth settings. I'll never buy an expensive phone off the net again - i'd prefer to pay $1000 from a shop rather than $900 of the net & have these problems.
Jan 11, 2007 | i-mate JAMin Smartphone
Lands Phones Logo
221 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
