Question about Toshiba Satellite P35-S611 Notebook
CD / dvd rom not detecteed on my laptop
Hi my dvd rom is no detected on my computer but there is power in it i can open and shut it. So can you help me please
  • Joeker001 Apr 06, 2008
    Same notebook, same problem. Occasionally my CD/DVD works, but most time it just doesn't recognize a CD in the drive. It does spin it, and the diagnostics say it's working properly.
    Thanks!
    Joe
Goto
support.microsoft.com/default.aspx/kb/929461
follow knowledge base instructions should clean up your missing dvd drive..
Posted on May 01, 2008
Fix DVD/CD ROM to work Acer M1610, Computer not detecting DVD/CD ROM. No drive is seen how to fix this, what are my options. OS is Vista
Hi rossclark3,
Try to check the jumper settings of your DVD/CD ROM if it is properly assigned as Master or Slave.
Afterwards, also check the cable connecting the DVD/CD ROM to the motherboard.
Finally, restart your PC and check the BIOS Setup if it can already detect your DVD/CD ROM.
Hope this helps you a lot.
Thank you for using FixYa!
Oct 29, 2011 | Computers & Internet
Hi, i am using LG dvd rom HL-DT-ST_DVD-RAM_GSA-H55N on Windows XP platform. my dvd writer is detecting cd's but not detecting dvd's.i had flashed the dvd rom by LG firmware but that does not...
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom restart your computer then plug them back in this should activate the found new hardware wizard
hope this helps you
Sep 10, 2011 | LG GSA-H55N DVD-RAM Burner
Dvd rom drive does not work
Try to open control panel then click add hardware. If you have entered the dialogue box, answer whatever is asked according to what you're searching. Then click whatever hardware your PC would like to detect then click finshed. After the detection, close the wizard box then try to open your DVD ROM and try it.
Hope this answers your question.
Feb 18, 2010 | Artec 16X DVD-ROM 48X CD-ROM Drive with...
My hp laptop cd rom is not detecting the cds. i want to formate my laptop.
Hi there, do not format now. Just try these.
Run the driver disk & install the CD/DVD driver. After finish the setup restart your pc or laptop. Hope that time your CD rom detecting the cds. But make sure, that your rom is working. Because if the cd rom is damaged then after formatting you can't install the operating system. May be your cd rom lens is damaged & that's why he can't read the cds or dvds. I suggest you Visit a service center & check the cd rom only. If you able to view the cd rom driver in side the my computer then, i am sure your vd rom lens is damaged.
Thanks & waiting for your feedback.
Feb 14, 2010 | HP Compaq nx6110 PC Laptop
No dvd/cd-rom driver detected my system can not detect cd/dvd drivers
Hi
Could you clarify, is this a laptop or a desktop computer? Please check device manager and tell me what do you see there, right click on my computer or computer which you will find either on the desktop or in the start menu. Select Manage. Then on the left side, see the device manager, now look on the right, do you see any unknown devices or any with ? yellow mark on them? how about cd/dvd drives?
Dec 13, 2009 | Dell Office Equipment & Supplies
Hi I have a Toshiba Tecra M2 laptop with Windows XP Pro SP3. My CD-RW/DVD-ROM/CD-ROM drive is not working. When I try to burn a disc, it says no recorder, or no disc in drive. Also, Windows doesn't seem to...
>> it says IDE #1 error when it boots up.
IDE #0 is your disk-drive.
IDE #1 is your CD/DVD drive.
So, take your computer to a qualified technician, to first check that the connectors (power, data) from the motherboard to the CD/DVD drive are good, and then, if necessary, to remove & replace the "dead" drive.
Oct 27, 2009 | Toshiba Tecra M2 Notebook
Hp cd rom dvd drive
Try this quick fix :
Get a screw driver, unscrew your machine and remove your drive. If you cant do this by yourself, just try and get a good technician to do it for you.
After this, power up your system normally without the drive connected.
Then shut down properly, and reconnect the drive, making sure that its firmly connected.
Then power on again and check it in the system BIOS if its now detected, then save and exit, then boot your system properly again.Then when the system boots, just right click on my computer, then properties, then select the hardwares tab, then click on device manager.
When you get to device manager page, try and locate DVD/CDrom Drives, then click on it, if your drive is there, then just right-click on it, and select uninstall, and after this, on that same page, click on 'Actions', and select "Scan for hardware changes". But if its not there. Just click on the "Actions, and Then select "Scan for hardware changes".
This should automatically out it back inside your My Computer page.
Hope this helps you out.
Jul 19, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My dvd/cd rom is not opening, checked hardware, not even listed
just check your dvd writer is open or not open because the some time not open the dvd driver then not detect
fist of all remove the dvd rom and reinstall because the some time remove the dvd drive and after reboot the laptop and check ..............ok
Apr 08, 2009 | Computers & Internet
MY COMPUTER DOES NOT SEE THE CD-ROM
my cd and dvd not detect of my computer how cd and dvd detect tell me a solution
Dec 25, 2008 | Computers & Internet
ACER ASPIRE 5100 DVD/CD ROM IS NOT DETECTED IN BIOS?
do you get an error 200 yet ? i got one here that does the same thing and its a bad motherboard. tried to replace cd drive and harddrive and was no help
the motherboard cost to much and not worth the part and labor
Dec 04, 2008 | Computers & Internet
Toshiba Satellite P35-S611 Notebook Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
