Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Weeda eater why does my weeda eater keep flooding and petrol run's through the carbie and i cannot get it to start My bc30 is brand new. I can get it to idle if I start it while tilting the motor 45 degrees toward the ground, but in no other position. If I quickly shake or rotate it ant this angle, it stops running. This would indicate some type of carburator malfunction. I took the carburator apart yet there is no apparent problem. There is a small spring-loded float-like device that may not be functioning properly due to over/under load of the small spring itself, I slightly streched the spring to see what effects this would produce. However the tiny spring, sprung from my grip and fell into the proverbial haystack. Now I am on the hunt to replace it.
  • 163 Answers
Try www.jackssmallengines.com
Posted on Nov 29, 2008
SOURCE:
I have a troybuilt weed eater. I just put a new carbeutor on and its not running right. It has compression but will not start?
check the position of the fuel lines to the primer or if part of the carby from the tank to the carby
the way it works is that the primer bulb sucks fuel through the carby to prime it so the tank line goes to the carby and the line from the primer back to the tank
could be flooded or the metering screws have to be adjusted
Jul 22, 2017 | Garden
Very hard to start the Murray M2500 weed eater
replace the diaphragm in the carby( note her e--kits are as costly as a new carby so check on e-bay for a replacement price
don't use e-mix fuels in small engines
Aug 20, 2016 | Garden
Diesel glow plug relay
the heading is diesel glow plug relay and then you go on about a choke and petrol inplug holes
what have you got a diesel engine or a petrol engine
May 17, 2017 | Cars & Trucks
Carbi keeps flooding started fine and rode for 10 mins then cut and wont start unless i drain the carbi and turn petrol of then starts for around 10 seconds then cuts out its a peewee 50 2010 model
the float inside the carb is probably stuck in the open position...you may need to remove the carb and have an overhaul kit installed in it....if you stored the unit without draining the fuel from the tank AND the carb, then the fuel probably went bad and has become "varnished". This fuel degradation can cause the float to stick and clog up the main and idle jets
Apr 27, 2011 | Yamaha YZ 125 Motorcycles
2 stroke Victor Mayfair Delux (old mower) Have cleaned our carbi. Plenty of petrol coming from. Can get it started but to keep it running with reasonable revs I have to keep the flooding device down with...
Hi, from your question it sounds like you have an idling problem. To fix this you have to adjust the idle speed screw that is located on top of the carb. Turn that screw in (clockwise) for faster idle speed. Hope this helps. All the best and good luck.
Feb 09, 2011 | Garden
Fuel coming (sometimes pouring) out of the airbox vent pipe when the engine is turned off. It will also continue for a time with the ignition off and then slow to a stop. But will sometimes start again...
Sounds like needle & seat in carbys could be sticking or float levels maybe to high when you turn your key on your fuel pump starts and this puts pressure on needle & seat and if floats are to high the petrol just keeps flowing Float is what stops petrol flooding the carbies, check minor things first like dirt in needle seat if you have a compressor give carbies a light blow out.
Jan 10, 2010 | Yamaha XJR 1300 SP Motorcycles
Kawasaki GT750 Fuel dumping
Sounds like the float valve is stuck in the carby and allowing fuel to keep flowing.
Give the carby bowl a light tap with some wood to free up the float valve. You may have to pull the carby off and have a look if that doesn't help. Fuel cannot bypass the float valve in normal operation.
Jul 25, 2009 | kawasaki GT 750 Motorcycles
Carbies willn't set float level,right floods,left sets to low
I don't know if its any help but I've fixed my Honda with similar problem. It turns out I reassembled the rich carbys air cut off valve incorrectly. Have you checked yours? I'm wondering if the cut off valves somehow affect the other parts of the carbys. Mine is running sweet now.
Apr 13, 2009 | 2001 kawasaki ER-5
Weeda eater
i have a ryobi BC30 bought july of 2007, it has always worked well for me ...but not when i start it , it will only run with the choke on ...... once i take off the coke it stops running........... is there some one out there that can help me get this trimmer ideling again.........  thank you
Aug 28, 2007 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
170 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
lnbn1975
Dennis Tokarzewski
Level 1 Expert
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
