Question about Austin HealthMate Air Purifier
Problem with smell coming from Austin Healthmate
We purchased the Austin Healthmate just one year ago. It was shut down for about a two week period and when we turned it back on, it emits a horrible sour smell. Since the filter only needs to be changed every three years, do you have any idea what the problem can be?
2 Suggested Answers
6ya staff
SOURCE:
alke35243
SOURCE: I bought a used Austin Air HealthMate and it has
I have the same problem although I figured it was due to the filter being close to five years old. I have had the Healthmate since 1996 and the current filter is 4 1/2 years old. The unit is in my son's room and I had noticed for a while (maybe the last 6 months or so) that his room had a foul sour smell to it. My wife & I thought it was our son as he is close to puberty and starting to need deodorant but I took the unit out of his room and the smell is gone. I'd be willing to bet that both you and I need a new filter.
Posted on Feb 04, 2011
Shark steam mop troubleshooting
This is a bad sign. The heating element has either come loose or the thermostat has failed to shut the heater down. Dont use it anymore. You can disassemble it and see what the damage is but the smell leads me to believe that it is damaged to the point that is should be replaced. Check the warranty to see if it is covered.
May 17, 2013 | Shark Euro-Pro Professional Steam Pocket...
I have a terrible smell coming out of my Mitsubishi air-con.
after making sure it will drain properly the best way to permanently remove smells is to use a "ozone machine" or a ionizer this attacks the odor causing molecules and breaks them down. 30-60 minutes from a powerful unit will do the trick , most carpet cleaning companies that also do water repairs have these machines and their rates vary. alpine air also makes a home unit and these are good to use in the home 24/7 as well
Jun 05, 2012 | Mitsubishi MSZ-GE24NA Mr. Slim Wall...
I have the Alpine Living Air machine - the green light does not come on just the amber one. I don't smell any ozone odor. Cleaned the plates but not sure if they have to be installed in any special...
How long have you owned machine? Plates need to be replaced periodically to be effective and to generate ozone. Depends on usage but at least every one-two years. They run about $15 a piece. I can get you some.
Jul 07, 2011 | Alpine Air XL-15 Air Purifier
I bought a used Austin Air HealthMate and it has an awful smell coming from it... it's similar to the fragrance that was in the house we purchased it from. We've had it running for over a week near an open...
Jan 18, 2011 | Austin HealthMate Air Purifier
I no longer smell the ozone smell that i used too.
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers.
May 29, 2010 | Ecoquest Breeze AT Living Air Purifier
Ionic breeze smells like a serious electrical short when I turn it on.
THEY RUN WITH A DIFFERENT KIND OF SMELL PEOPLE ARE NOT USED TO. ITS A HIGH VOLTAGE SCARY SMELL .IF IT SEEMS TO WORK OK THAN IT MIGHT BE OK
Apr 23, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
No clean air smell/crackling & static
To stop the crackling sound, you need to remove all of the dust particles from the wire in the back. Sometimes when the unit is extremely dirty you can see sparks emanating from the wire, this is what causes the crackling sound. The unit has a built in cleaner you can lift up and down to perform this task, located on the top, but this doesn't work extremely well.
I usually take a can of compressed air and blow as much of the dust I can off the wire and all surrounding internal areas as I can. This along with a thorough cleaning of the blades should eliminate the crackling noise. Of course, make sure the device is unplugged before performing any cleaning.
Not sure about the smell though. Mine has started to smell a little strange and I haven't figured out how to fix that problem.
Oct 01, 2008 | Ionic Pro TURBO Air Purifier
XL-15 Classic Living Air emmitting Foul Odor!!
Ionizers do cause a bad odor to happen. I work in the copier business and do work around machines that can cause an ozone to happen when there are ran. Copiers like ionizers can cause an ozone to happen because the air particles are being electrically charged. The smell isn't good to be breathing in as well.
Here is an EPA report about ionizers
The Consumer Products Safety Commission is going to be making a decision about the health effects on ionizers by the end of the year. Their decision can effect selling ionizers all together.
This industry should have been regulated years ago and after what happened to Sharper Image this year due to their arrogance it isn't doing the industry any favors. They went out of business because of Consumer Reports findings and tried to sue them for it.
If you really want the air in your house cleaned, the best way to do it is using a hepa filter.
Jul 26, 2008 | Ecoquest Living Air Classic Air Purifier
Air Purifier smells like chlorine
Mine does too. Did a little research - I guess all air filters let out a little bit of ozone. Some describe the smell of ozone to be something like bleach yet others say it smells like geraniums or even "sparks" (like the sparks that come off of the bumper car ride at the fair...hmm...interesting). Not sure which to believe, but I know mine smells.
I found a manual talking about reducing this smell. Said the first couple of weeks are the worst of it, but if it still bothers you, you could install an "activiated carbon filter" down stream from the air filter, or go through complicated instructions (for whatever model they were talking about) to go into the of the machine and switch stuff around.
Both solutionssound complicated to me.
I'm just happy knowing the smell is normal and that it is actually working. Think I'll live with the smell.
Dec 13, 2007 | Brookstone Pure-Ion (506840) Air Purifier
Austin HealthMate Air Purifier Logo
384 people viewed this question
Top Austin Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you an Austin Air Purifier Expert? Answer questions, earn points and help others
